Naive Harry's proposal is not that bad....
10 char to it..
I will Speak only of a Gaming system... If you have some specific requirements like Video editing and Advanced graphics processing... please dont read any further..
The problem is that no build will let you game for 3 more years unless you skimp on some new features that come out....
You need to have a stable path of upgrade....
If you dont plan to upgrade in 3 years.. go for a Core 2 Duo E 7400... Get a good cooler like the Thermalright Ifx or the Scythe Mugen 2 and over clock it like hell... Except GTA 4... quad cores are really not that needed for gaming
check this review..
Prolimatech Megahalems and 12 Other Coolers for Intel Core i7 Overclocking (page 21) - X-bit labs
Get a decent Mobo that supports Sli...
IMHO Gigabyte ep45-ud3r... Nvidia mobos are not that great nowadays..
If you like Upgrading your system once in a while... You can go for AMD Phenom II X3 720 BE... Again overclock it like mad...
You can buy a good AM3 mobo now.. then you can Change the processor as better Phenom II models come out....AMD always makes everything backward compatible..:angel1:
Going i7 isnt very wise as of now... It will take eat from your GFX card budget.. But you can wait for an i5.. if you have the patience....This will allow you a more powerful upgrade path than the AMD.. But you will be shackled by Intels bloody strategy of " a new chipset for every new cpu ":devil2:
IMHO Even the E 7400 will never bottleneck ur gpu... So an i7 is not needed
Then for the present get a GTX 275...
If you are ok with Sli.. Get one GTX 260 With larger amount memory..
Try it out and if you still want more performance.. Get one more and Sli it...
If you dont want to Spend that much... twin Radeon HD 4770's in crossfire Equals the GTX 275...
Get a 650 w power supply or at the max 750w..(no more)... Corsair is the best.. But Tagan BZ etc are also decent
Get the Samsung 2233w.. But soon Nvidia 3D vision will become popular...
Its already getting really awesome reviews.. Once it becomes available in India cheap... Then you can get an easy exchange (probably) with the 3D vision recommended Samsung 2233rz monitor..(of course if you want to plonk for an imported 2233rz, go ahead.. Its 120hz refresh rate itself is being mightly praised)
If you can take the trouble.. Get 2 x 500gb WD hard drives and put it on RAID 0 config...
Its worth it... over a single 1TB drive..
For the Rest of the components.. you can ask the TE members itself...
They are well knowledged in the Best components and specific model numbers...(while a noob like me ain't)...
Please wake up.. If you slept off while reading the long bore....
BTW
@ naive_harry.... Have you got your system??? or are you still waiting for october..
By Vinny
There will always be better options round the corner. If you want something, just go ahead and buy it.
I remember buying a pentium 120 mhz system with 4 mb ram and a whoppin 1 gb hdd for 60k. Maybe i should have waited 12 years for an i7 system
lol Vinny you nailed the reply...
