The_Falcon
Explorer
^^I certainly won't recommend to keep it outside.. We lost 3 top loaders that way! And all of them were different brands. One was Voltas, which gave up in six months flat, another LG lasted a year, and one Videocon for abt a year before it too started to act up.. I now stay at Mumbai, so no Verandha for me now. But the WMs I am talking about were in Punjab. I don't think they are made to last in open weather conditions. Better try to keep it somewhere inside and make some plumbing arrangements for water in/out if you don't already hav such a place. Why not the Kitchen? Its a front loader and can easily fit under the counter if you hav some spare space.
Sent from my BlackBerry 8520 using Tapatalk
Finally ... booked Bosch Maxx Frontloader - WAE - 20260IN
Price - 30500.
Those older models with mechanical knobs could be kept outside under a shade. I am using my IFB Executive Plus (1999 Model) sitting there under a ledge. But if there is any electronic switches then it would definitely die even if its a FL WM. My neighbor's top-loader (IFB) died sitting outside in the open without any shade. Now they are using a FL-WM, again with no shade. Lets see how long that lasts.
Congrats !
All of them were Fully Automatics with electronic controls.
Price - 30500.
Hi All.
by reading all the above discussions - One thing for sure that I wont be buying a IFB.
Now need to final one out of the following two models from IFB :
1) Maxx Frontloader 60 cm width WAE20260IN
2) Bosch Classixx Frontloader 60 cm width WAX18260IN
One major diff is the capacity But the 6.5 Kg has modes such as Easy Iron & Stains.Dont know how much crucial they are.And the RPM is more.
Please can someone tell me the importance or no imp of such factors .
The link is Products - Washing Machines - Washing Machines - Front Loading - List
Looks like quoted very old post. please ignore
Hey, I'm also planning on buying a washing machine....have shortlisted
1. Bosch WAE20260IN
2. Siemens WM12E360IN
How is your machine working for u so far?
1. Bosch WAE20260IN
Hi guys,if i were in your place,i would stay away from ifb.
ifb is all china stuff while bosch is all german import .one factory to rule them all.
both siemens and bosch use one factory to roll out their gear for consumer market.
i am using siemens dishwasher and cant be more happier.
i have ifb microwave as well and honestly ,unless you know higher ups at ifb service center,stay away.
Hi MK76, I am planning to buy a Bosch WM, please share your review, also please checkFinally ... booked Bosch Maxx Frontloader - WAE - 20260IN
Price - 30500.
Thanks mk76, purchased Bosch WAX18260IN, yesterday eve. the demo guy came and told us how to use it. It is silent machine only makes some noise at 900 RPM while spinning. Wash quality is good and the clothes were approx 80% dry.@Rajen : I was sceptical on its performance due to hard water supply at my place, but after an year no complaints. Note that I do not use a water softener. Also that the machine is kept in my verandah (under shade though). So in all few major unfavourable conditions to run.. still the machine is working without troubles. Very satisfied at the performance. Super silent as well.
Few minor points I think should have been taken care of.
1) Start/Pause buttons are little hard to press.. plus not too satisfying when pressed. You tend to check twice if it worked on not.
2) Display not too bright for outside. And no audible notification on completion
3) Mold has grown on the front part. I think we did not clean it thoroughly. Someday I will read on how to clean it.
Sorry, could not check your video at the moment .. little short on time.
