Help!!! Suggest me Cpu cooler for Core i7 2600K?
Tenida
Forerunner
Hi, folks
I am spending extra 3.5k to buy Intel Core i7 2600k for future needs as suggested by many forum friends.But Cm hyper 212+ is not good enough to cool this powerful monster processor when HT is on.
So suggest me a Cpu cooler within Rs 3.8K.I am having MSI Z68A-GD80(B3) motherboard and GSkill Ripjaws X rams.
So suggest me fast
Note:- Suggest me only air cooler :clap::bleh::ohyeah:
Thanks buddy.
Can you say where Noctua NH-U12P SE2 120mm SSO is available? AFAIK its out-of-stock in Itwares. Last 2 pcs are taken by tkin and mukherjee
^^pleaseif possible find me a source which states that the Hyper 212+ can not handle the 2600K at stock even with Hyper Threading ON? IMO it is more than sufficient for that CPU at stock speeds...even a little OC would be acceptable with it.
He has a 2600K really doubt he intends to run at stock or little over :P GO GO 5ghz !!!
My suggestion is look for a Ven X it might take a little time to find but its performance is well worth it. Also it will have no issues with ram clearance etc.
^^ Oh well, yeah I understand now :) ....but he had only mentioned only about HT thats why was wondering incase I had missed anything else...
Bought Coolermaster V6GT @ 3.8k
Assembled Autobot Bumblebee-
My System
CM V6GT Blue
CM V6GT Red
CM V6GT Purple
More pics coming up in separate thread
One slot is hiding by the cooler.But it will not create a problem, if i want to add ram in 1st slot.
