Myth_Pharoah said:
C2D E7300 @ 6K
ASUS P5Q-Pro @ 9.5K
2 x 2GB G-Skill @ 3.5K
HD4850 @ 9.5k
About 29k. Sounds like a decent deal.
If you've made up your mind:-
The C2D E7300
= 5,800 or less
Mobo= I'd prefer spending as less as possible here due to the fact that the motherboard will become redundant when you do a major upgrade, that fact aside, you can now upgrade to a E8400/E8600 as a midpoint before upgrading to something better, i do not recommend it, however. Again, i'll suggest you go for the gigabyte alternative, P43/45 are unaffected by said problems and lastly, it's cheaper.
= 9,000/9,500
RAM= Stick to Transcend 2GBx2 800Mhz modules, don't worry about higher bandwidths and brandnames, that'll get you the most bang for your buck.
= 2,500 or less
GPU= The Palit HD4850(512MBDDR3, 256Bit) is readily available for little over 8,500, go with that and don't bother with factory OC'ed and higher RAM variants.
Total
= Less than 26,000 INR
You can deduct another 4k or so if you choose going for a cheaper mobo(My personal recommendation is the MSI P43 NEO @about Rs. 5k, that would bring CPU+MOBO+RAM to ~14k) and trade some OC-capability for better VFM.
Rest is upto you, do keep us updated :hap5:
@madnav
Im not recommending either mobo, im suggesting a cheaper option, even so, given the choice, i'd pick the gigabyte over the ASUS.
