Review How a dead GFX Card is made alive professionally.
In this article I will show you how a dead graphics card is repaired. No oven baking, no do-it-yourself type trikes, just a pure professional repairs.
Meet the victim, my old no display, dead ATI-Radeon X1650 graphics card.
Removing the heat sink.
Thermal compound on the chip cleaned.
Now circuit board is installed on a BGA chip reflow machine.
Heater head mounted properly.
Machine in action
Within a minute chip is out.
There is very little space between chip and circuit board approx. 0.1mm still you can see their is dust under the chip. This dust, heat and moisture together sometimes oxides and breaks these fine connection resulting a GPU failure.
Chip is mounted on a reballing mount.
You can see many connection pins have gone black due to dust and oxide layer.
Heat cleaning the chip connection terminal.
Preparing the chip for new BGA soldering balls. Flux, 0.6mm lead free soldering BGA balls and grid.
Some close look on BGA soldering balls
Grid aliened, chip ready for reballing.
Ball properly falls into place.
All missed holes are carefully populated with a ball using a fine needle.
Perfect. New shiny ball are in place. Looks nice
Little heat for removal of any excise flux applied during the ball placement stage.
Now chip is carefully placed back on the circuit and controlled heat is applied for re-soldering.
Perfect chip re-soldering
New thermal compound is applied and heat sink installed.
Test system ready. Now is the time that will show whether the GPU is back to life or gone forever.
It’s live.. Success.
Some GTA san andreas run shows that GPU is 100% fine.
Hope you like this article.
Regards
Rakesh Sharma
Source / More Info
AMD and NVidia sell their chips to OEM only that too in big quantity. Only fake or refurbished chips are available in market.. I usually don't have faith in such Chines dealers. Getting single chip from abroad for just a repair is way too expensive and only practical if you are fixing an expensive card.
My ATI 6850 went kaput, i found a chip on ebay for 20$, and i paid the repair guy 1000/- . The chip was brand new, card is working fine for last 3 months now.
