PC Peripherals How many fans does your chassis have?
yeah I get that, I have 4 ML120's which can also run at 2400rpm, but I run them at 1k -1.5k rpms, higher rpms means better temps but a lot more dust as well.
I have 3 x 120mm in front. 3 x 120mm in side. 6 x 120 mm top. 1 x 120mm rear. Total 13 fans :p may be in future, bottom me laga duga 2 x 120 mm more ;) most of this fans are frostec airflow 57fcm version. all are controlled via smart fan feature by system.
  • Wow
Reactions: enthusiast29
How did I miss this thread -_-
3x120mm GPU Rad exhaust - Top
3x140mm P14 PWM AIO Rad exhaust - Front
4x120mm P12 Slim PWM PST intake - Side
3x140mm P14 PWM PST intake - Bottom
1x140mm P14 PWM PST exhaust - Rear
Might try push-pull on rads when I get some time.
Reactions: blackhorn
PS - how do you guys keep your PC so clean? I live in NOIDA and it's so god damn dusty everywhere. I will need to keep cleaning it almost every few hours to keep it that clean. Any pro tips ?
Create positive pressure system i.e. higher intake than exhaust. That way only air getting in the case is from filters instead of gaps etc. .
Used Pantyhose as air filter :p:D
BTW, I don't use any dust filter. Maybe its time I added some. Maybe that can reduce the dust filter maybe by certain amount.
Front Intake: Coolermasters stock 230mm red LED fan @ 700 RPM, 110 CFM, 19 dBA
Side Panel Intake : Coolermasters stock 230mm black @ 700 RPM, 110 CFM, 19 dBA
Top Exhaust: Antec Prizm 120mm ARGB @ 2k RPM, 45.03 CFM, 32.6dBA
Rear Exhaust: Antec Prizm 120mm ARGB @2k RPM, 45.03 CFM, 32.6dBA
I have a corsair 760T full tower but i only use 2x front 140mm ,1x rear 140mm no top fan along with cpu cooler Noctua NH-D15 cromax single 140mm fan.
By the way, can someone tell me which fan is better among Cooler master sickleflow and Arctic p12, if anyone used both?
Let me know if there’s anything better than these but within 800?
(Sry didn’t want to create new thread just for this)
+1 for Arctic, may be for me but it's always superior in performance and their customer support is excellent.
I have great experience with cooler master sickle flow fans. They are silent even at max speed. and they last a long long time. I still use mine which i bought in 2014-15. It was a red colour led fan. The red LEDs are dead now but fan still works flawlessly.
Reactions: Ssreek
2 x 200 mm ARGB Fans (Front) I 1 X 120 mm Fans (Rear).
Here are the idle temps of 5800X (ambient temperature of 22 degrees right now. Yeah, this is how a summer is in Bengaluru :D) in Eco mode.
3 for the desktop
Top, bottom, and the rear .
9 on the server
2 bottom.
1 rear
3 on top
3 in front
I bought Cougar MX 410 Mesh G RGB
Which has
3x 120mm ARGB fans in front
1x 120mm ARGB fan in rear
Deepcool AK400 which has 1x 120mm fan
Want to add similar another 1x 120mm fan for the cooler for push-pull setup.
5 fans not counting the CPU cooler and GPU fans.
2 front intakes, 2 exhausts on top, 1 exhaust behind. All 2000 rpm PWM 120mm.
Ps. Is anyone using the "fan control" software from GitHub?
