I asked because he said one GPU blower and I didn't see any GPU unless I misunderstood.where we suppose to discuss that![]()
You have a dual system case is it? Like one of the Phanteks ones?80mm on minor psu
120mm on major psu
There was a time when I used to run dual VIP 300W PSUs. One purely for the motherboard and processor, second for GPU and accessories. The fan on the case also fits the theme of this thread lolIf not I am really curious to see a dual PSU system. I
Is the Gentle Typhoon still available?
I've a CM HAF 932 where there's a legal space to house 2 PSUs..top and bottom mount.You have a dual system case is it? Like one of the Phanteks ones?
If not I am really curious to see a dual PSU system. I know the Lian Li O11 has the option for a 2nd PSU but never seen one in TE.
Man you are brute forcing too much. Whats your CPU/GPU/case/cooler?I had total of 8 fans....2*2500rpm pwm generic for intake....1 1700 rpm pwm deepcool for intake....
2*4000rpm pwm generic for exhaust.....1*1700rpm pwm deepcool for exhaust and 2*1700rpm pwm deepcool fans on cpu cooler.....
4000rpm fans are like jet engine.....while rendering cpu temps went uptill 75-80c....but will soon move to liquid cooler for sake of less noise
Guys, does anyone have that spare wire that is used to attach fans to the cpu tower coolers?
I wanted to attach a second fan to my tower cooler but I don’t have that wire thing which is used to attach fans. Was wondering if any of you guys have one?
Thermalright Ultra 120!Please help me recollect which CPU Cooler that is... for the life of me I can't remember the name!
NISUN INC PWM 3 Way Sleeved 4 Pin Female to 3-4 pin Male Splitter PC Fan Power Extension Cable (26cm) : Amazon.in: Computers & Accessories
NISUN INC PWM 3 Way Sleeved 4 Pin Female to 3-4 pin Male Splitter PC Fan Power Extension Cable (26cm) : Amazon.in: Computers & Accessorieswww.amazon.in
Oh my bad... Thats a tricky part to get. Usually they are specific to the cooler you are using.I meant like the steel wire by which you hang/attach the cpu fan on the tower cooler.
Negative pressure inside is good...using on ryzen 2700 with Gammaxx V2 and 2080Super FE inside Deepcool D shield v2 mid-tower.Man you are brute forcing too much. Whats your CPU/GPU/case/cooler?
You can do the jugaad using zipties if heatsink is not big.....i did the sameOh my bad... Thats a tricky part to get. Usually they are specific to the cooler you are using.
CPU temp's way too much. I use a Noctua NH-U14S on a 3900X and temps dont hit that much.Negative pressure inside is good...using on ryzen 2700 with Gammaxx V2 and 2080Super FE inside Deepcool D shield v2 mid-tower.
But will be changing to liquid cooler not liking the noise now or might go for noctua or other big one
I've got 4 Add RGB fans , more than enough cooling , if i get more it would be just to get 2 on top for more RGBCurious why are you guys buying so many fans? How many fans does your chassis have?
