How To Connect Sony LED TV To 5.1 Speaker System...
Ok,
I Am Really Impressed Logitech Z906 Which Is Way More Than My Budget But I can buy if it is worth it
I Can Connect It To HD STB Via Optical Output and watch tv in 5.1 audio
But The Problem Is I Want To Watch FHD Movies Through USB For Which I Have To Buy A Dvd Player With USB Drive...
But All The Dvd players I Saw Had Analog Audio Output
Is There Any Device Which Can Convert Analog Audio Output To Digital Output ?
Should I Buy Z906 Going Above My Budget ? Is It Worth It ??
Please Help Me Out![DOUBLEPOST=1414665047][/DOUBLEPOST]
This should suffice your requirements I believe. Philips HTS5520, costs ~13K.
http://www.philips.co.in/c-p/HTS5520_94/5.1-home-theater/specifications
It comes with Coaxial In. Take a demo. I did like the SQ.
No philips For me pls
i had a pretty bad experience with my previous Philips products
Whic One would be Better In Terms Of SQ ?
Edifier 5100 Pro + Philips DVD player with 5.1 out ?
Or
Sony IV 300 ??
Why dont you get a HTIB, I would recommend the YHT 299, slightly above the Z906, but totally worth as you would be able connect multiple devices, and if your TV supports ARC, you should get HD audio through your USB movie play back as well, worse case get the WD media player if you dont have ARC. But, with the HTIB you can easily switch between devices and have a well calibrated system. There are models cheaper than the YHT 299 as well, but I would recommend the former, since it hits the sweet-spot.
I Have A 40" Sony R482B Led Tv And Planning To Buy Edifier DA5100 5.1 Or F&D F6000U..
But I Am Not Able To Understand How Will I Connect Them To Get True 5.1 Surround Sound Experience
My Led Tv Has Only 3.5mm Audio Out Which I Believe Will Only Give Me Stereo Output
Please Help Me Figuring Out This Problem..
P.S - I Will Also Be Buying A HD STB(Videocon,Dish Tv Or Tata Sky) As Soon As My Current Recharge Gets Over
You have got any final solution ??
