[How-to] Flash custom firmware (CFW) for Nokia S60v5 devices
My Internet browser doesn't seem to be working after installing CFW. It just quits when i open it...Is there any step i have to perform after installing CFW? Is there any soln other than performing a hard reset...I already have Opera but need the Internet browser as well
Anyone tell me the pro's of this CFW rather than the original firmware.... Also any CFW avaialble for e71???
hi
I want to flash n86 8mp with cfw..I have installed jaf with emu key..When i click on flash,it says power up ,then i put in the battery,the phone goes in mass storage mode after inserting battery in the phone and then JAF shows phone not found..even tried during powering up the phone,the phone turns on immediately after pressing power button..
Please help...
here is the log
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.34.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-484\
Searching for default location of ini...
Checking path: \Products\RM-484\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-484\RM-484_30.009_prd.core.fpsx
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-484\RM-484_30.009_017_prd.language.fpsx
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-484\RM-484_30.009_54.1_prd.customer.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-484\RM-484_30.009_003_U001.uda.fpsx
Detected P-KEY: 90009699
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Not found!!!
I have got the error msg as "warning!warning!warning! failed to beckup imei. do you want to continue?"
should i press "yes" or "no"
and what does it mean? what are possible reasons for this type of msg???????
plz do reply ASP..........thanks in advance
and in JAF box something like this
Backing up CRT...
Detected P-KEY: 90009B6C
Reading IMEI..
Failed! Aborting!
Failed to backup CRT
