I gave into the temptation and installed Vista ultimate as my 3rd OS (other two being XP and Suse 10.1). As a precaution, i downloaded vista ready drivers for my xfx 7600 gs, and MSI 965P Neo mobo(lan,realtek sound, intel inf etc.) before installing vista...
everything is working fine..i set up the lan for my sify connection and i am able to ping the server from my system..but the SIFY client does not install as it requires the trend micro AntiVirus to install along with it..:no: it just exits giving a message tht it is unable to dnload the antivirus...:no: So any1 using Vista and has a sify connection...pls help...
Btw, the sify client installer does not mention Vista in its OS compatibility list...so does it mean tht SIFY Client doesnt work on Vista??
Second, i'm not able to make my 4.1 speakers work properly with the realtek sound app on vista...the rear speakers sound as if they are in karaoke mode...:| The rear channel sliders are all the way upto full, but still, they hardly produce any sound..:no:
they just work gr8 with the realtek app(older version) on my XP Pro SP2 in the same system..On Vista, Winamp and WMP sound as if they are working in 2.1 mode even when i've chosen quadraphonic setup in the realtek app.. Any help on the same will be much appreciated...
