raksrules
Oracle
I use flexget for p**n.
It parses the torrent site RSS feeds and picks up torrents based on a config.yml file. The captured torrent links are then added to qbittorrent which I use as my torrent client on my Raspberry. The only reason for using qbittorrent over deluge is that it allows me to add custom trackers.
Installation of flexget is pretty simple (sudo pip3 install flexget) but the config.yml is a pain.
Then its upto cron to run the job at say 10 min intervals.
If you want I can share my scripts with you.
Thanks for that info. Actually I recently became member of IPT and got a seedbox for a month so after doing that I was made aware of stuff like autodl-irssi as to get a good ratio on IPT, I needed to download torrents (freeleech) as soon as they are posted and for that I setup autodl-irssi but once I have built ratio, I guess I will no longer use seedbox and then keep leeching and zapping and once my ratio is in danger again, I will again get a month of seedbox.
I am actually contemplating getting RPi but I am still confused whether I want to or not and I also have a spare windows laptop with good config but no screen which I think I can use as well for getting something running 24x7 at home if I want to.
