blr_p
Quasar
That much noise means the bearings are failing. If there was a way to replace them it would be like new.We also have the bigger Crompton Ozone 55l cooler, which sounds like a aeroplane taking off making it unusable while WFH.
How did you test the hardness ?3) is water container steel or plastic? I get hard (150-180ppm) water most of the time.
A TDS meter is misleading because it tests for presence of all salts. Higher the number more conductive the water is which is meaningless.
Hardness is down to calcium salts only and there are test kits you can get to measure it.
Do you find much scale left on the bottom if you say boil a pot of water to the end ?
Hardness also varies depending on the time of the year. It will be the least during the rainy season and highest in the dry season.
Interesting. So what speed is the fan running it at then ? when it is quiet vs. louderIt's very simple. See, how you use fan regulator to control ceiling fan? Same principle here. Only I'm using dimmer instead of a fan regulator.
I made this extension 6 years ago only for silencing the coolers. Dimmer controls the fan speed. If you go to local shops to buy dimmer they try to sell you fan regulator. Both look same but operate differently.
This has made the fan of my cooler inaudible but hasn't affected cooling a bit.
If you know how many blades the fan has then fan speed can be determined using a FFT app.
Another thing that will contribute to noise is dust stuck on the fan which should be cleaned if possible.
He is saying a dimmer used for resistive light loads won't be suitable. Because its just a potentiometer.About the answer from the link, the dude is wrong suggesting lights are resistive load. Most light sources we use like CFL and LED are inductive.
If your dimmer is suitable for CFL & LED which are inductive then it is also suitable for a motor.
Thing is you also said not to use a fan regulator. A fan motor is an inductive load as well. No different to a cooler motor. Why then is a fan regulator not suitable ?
The motor. Whether it uses brushes or is brush-less. This is the determining factor rather than inductive load or not. Because ALL motors are inductive.
A motor with brushes can be regulated with potentiometer but brushless requires a different regulator. The one that works with CFL& LED presumably.
