- Expected Price (Rs)
- 15000
- Shipping from
- Mumbai
- Item Condition
- 4 out of 5
- Payment Options
- Bank Transfer
- Purchase Date
- Dec 19, 2020
- Shipping Charges
- Excluded - at actuals
- Have you provided two pics?
- Yes
- Remaining Warranty Period
- CoolerMaster GPU Vertical Mount - 4 months remaining (Dec 19th, 2021), Others no warranty remaining but will provide 3 day personal testing warranty
- Invoice Available?
- Yes
- Reason for Sale
- Need Money. Not using these items anymore.
For Sale -
1.) CORSAIR Graphite Series 760T Full Tower Arctic White (PC Case) -
Price -8500₹ 7200₹
Condition - 3.5/5 TBH, further details below -
1.) Has a few scratches on the see through door panel if you look closely with light (not visible to the naked eye) unnoticeable like that. Fully visible and will not disappoint.
2.) Right side door panel has a few scratches but people barely tend to look or display the right side of the case.
3.) Overall case white colour has faded over the years to an off-white colour.
4.) At the GPU grill section, one grill was cut to put in my GPU display port cable (had installed the cooler master vertical GPU pcie mount V2). I have temporarily taped the cut pieces, if you want you can remove, it will be no issue and totally covered from an aesthetic point of view. If you want , you could stick it back permanently or weld it back some how (Not needed) It won’t be noticeable when the plates are installed or even if the GPU is installed at that area vertically or horizontally.
5.) Front DVD drive bay slider spring was broken, but I stuck it so it doesn’t pop down anymore. The panel can be removed to put a DVD drive with no issues.
6.) Front panel was RMA’d twice due to faulty LED lighting, corsair sent me a red LED version and a white LED replacement kit, not sure which I ended up putting last. Now it works perfectly fine. Power button does require a bit of force, it is normal. USB ports all work but contains dust (can be air cleaned or with a brush).
7.) The front grill + dust filter mesh is of two parts and can be separated. I prefered removing the grill and only kept the dust filter mesh on for aesthetic purposes (more rgb can be seen from the 2 front fans).
8.) It includes the 3 stock fans that came with it and works flawlessly. 2 White LED AF140L Fans + 1 Stock Non-LED AF140L Fan (Grey Fan Blades) Picture of this 1 fan is not in the album but will provide pictures when asked.
9.) Do not use the top white cover for the case if you have a radiator installed there, I personally did not use it at all. It can cause less air circulation within the case. Maybe if you are water cooling the PC with pumps, pipes etc then you could use it, upto you.
10.) I have cleaned the cabinet/case as much as I humanly could. If you would like to do a thorough job, Google how to remove the whole front panel, honestly everything looked dust free and fine to me.
Place and Date of Purchase - The IT Wares (Offline), above PrimeABGB, Simlim Square, Lamington Rd., Mumbai. Bought around Q1 2017.
Original Price Purchased - 15,500₹
Warranty and Bill - No Warranty Remaining (Will provide 3 day personal testing warranty). May have original bill, have to find.
Notes - This is a great cabinet/case, can hold 6 Sata HDD’s and 4 Sata SDD’s. That is 2x HDD drive bays that hold 3x HDD’s in each drive bay. 4x separate removable panelled slots for SDD drives. Good for Chia Mining. Manual will be provided. Box / Original packing “maybe” available. (Have to find, if I cannot find by time of sale then it’s not available). Would prefer local buyer but will also be open to shipping country wide. Shipping will be costly as this will be a big boxed item, so be prepared to shell out for this, no worries we shall discuss. I think I have covered all the details possibly that I could think of, DM me if you have any questions.
Edit - Cabinet / Case Fans could be sold separately (I require a buyer for the PC Cabinet / Case first.)
2x - White LED AF140L Fans - 800₹ each.
1x - Stock AF140L Grey Blade Fan - 600₹. (Not in pictures, but will provide upon interest.)
760T Cabinet / Case Only -6000₹. 5000₹.
2.) CORSAIR LL140 RGB 140mm Dual Light Loop Fans - 3 Fans
Price - 6500₹ x 3 Fans with 1 Lighting Node + 1 RGB LED Controller Hub.
Condition - 5/5
1.) All RGB LED’s fine and works flawlessly. Cools well without any issue. All RGB effects via iCUE is working perfectly.
2.) Slight dust, but I will clean it as much as I can before sale.
3.) Dual pack will come with the Lighting Node device for its RGB connections and the RGB LED Controller hub as provided in the box along with its wires etc. 3rd fan will be just by itself, as I am looking to sell all 3 together.
Place and Date of Purchase - Vedant Computers. Bought around mid 2018.
Original Price Purchased - Had bought 2 x dual packs for around 6,500₹ each. So that‘s 13,000₹, but I’m selling only 3 fans so that’s 9750₹ for 3 fanS with accessories.
Warranty and Bill - No Warranty (Will provide 3 day personal testing warranty). Can find, should be available.
Notes - I still have the original box for one dual pack, but one fan will not have a box as it will be single. Will pack all together safely.
3.) Cooler Master Universal Vertical GPU Holder Kit Ver.2 - Not Available Anymore.
Price - 3000₹
Condition - 5/5
No usage marks etc. Excellent condition.
Place and Date of Purchase - Bought from Amazon India on 19th Dec 2020,
Original Price Purchased - 3,899₹
Warranty and Bill - Warranty available till 19th Dec 2021. Bill available and will provide over email or WhatsApp.
Notes - Original box available along with manual and original screws.
4.) Antlion Audio ModMic Noise Cancelling Attachable Boom Microphone with Mute Switch (Black) - SOLD
Price - 2200₹
Condition - Works perfectly and was barely used. Only the boom mic sponge cover is peeling off a bit, can be replaced with 3rd party.
Place and Date of Purchase - Not sure where, but date of purchase is around Q3 2018.
Original Price Purchased - Around 4,300₹
Warranty and Bill - No Warranty (Will provide 3 day personal testing warranty). Not sure about bill.
Notes - All accessories included, including the original case box with 5 piece wire wraps and 2 magnets (can be used on 2 headphones) also one 3M double sided tape (You can add your own sticky tape no worries). Manual included.
5.) Sony DUALSHOCK 4 USB Wireless Adapter -
Price - 2100₹
Condition - 5/5 (Barely used, works fine).
Place and Date of Purchase - Imported it, can’t remember place of purchase but date of purchase is around late 2018.
Original Price Purchased - Around 4,200₹
Warranty and Bill - No Warranty (Will provide 3 day personal testing warranty). Don’t have bill.
Notes - Box / Original packing “maybe” available. (Have to find, if I cannot find by time of sale then it’s not available).
Details -
Some items prices slightly negotiable, low ballers and time wasters stay away.
Pictures/Videos provided in 2 Imgur albums . Some pictures/videos contain the date of 3rd September as I planned to post it then but got delayed. Some picture/videos do not contain name and date as they were taken just before dismantling my PC and I forgot to write my details. You can have a look of how my PC looked with the LL140 RGB fans and the vertical GPU mount incase you’d like to purchase all 3 items.
Shipping from - Mumbai, 400050
Mode of Payment - Google Pay or Bank Transfer / Cash if in person. (Payment first then shipping tracking receipt)
Courier - DTDC (50/50 Split) If in same city you can pickup or arrange WeFast at 100₹. (Cabinet Case ExceptIonal, Will Discuss and Figure).
Packaging - Everything will be packed well, no worries, will even provide packing pictures after payment.
For any other info or if you require additional pictures/videos then DM me. Cheers!
Imgur Album 1 Please check. 50 photos.
Imgur Album 2 Please check. 20 photos.
Price -
Condition - 5/5
Condition - 5/5
Price - 2100₹
Details -
