laxmi24
Contributor
Thanks, but i do not have any warranty. HCL give me a total overall 1 year warranty. So if you say i need to contact them, i have to pay little bit extra or i have to contact any private expart.
Where should i get the serial no. HCL does not give any prove as it is an intel motherboard. I open my cabinet and there is a label showing a picture of motherboard, there i found the name of the motherboard DG31PR. Then i search the internet with the product then i find it is a Intel product. Even at the time of Post the display showing HCL motherboard and lintel chipset. "HCL Best Assured" logo appeared on the full screen and the small 'Intel' logo on the bellow left hand side.
And i do not have any prove of the motherboard of intel, No manual, No Invioce,No cable(IDE) Nothing. Even "HCL Best Assured" is printed on the motherboard.
I download the product guide from the internet.
And one mote thing my cabinet is not an ATX, it is thin cabinet. it is only 3.5 inch in breath. So my inside is too jam with the cable and other devices. I upload some picture of my cabinet , front view and side view.
There is 24 power cable connection on the motherboard as usual, my in my case the connection is bellow hdd. if i want to unplug the first i need to remove the HDD from its place.There is one and only a single CPU fan in my cabinet at all which is damage every 5 or 6 month. And the PSU is also low output. I think I need to change the cabinet and smps. What did you say. If your answer is yes then please suggest me some band or model number, There is too many model in the market, I am totally confused about it.
My system temparature is too much about 72 degree. How to cool it down. Is it also motherboard problem.???????
Oh! i forgot to say one thing that i check today morning. that i told about a problem, When i entered to bios hardware monitoring page my computer getting hang. Thanks friend Thank you very much, After update the Bios that particullar issue is gone. I entered the page today morning but it does not hang, The fan speed is showing continuously, . it Update the speed every second. As it show the speed stated with 937 rpm then it increase to 2172 rpm within 6 minute. but some time it show N/A or sometime more than 1,60,000. But when i observe the fan it moving continously at the same speed . But yes it is moving at 1/4th or its original speed. And i saw the case at my previous fan when fan stop moving the computer take auto - restart.
