vb01
Q: What is your budget?
50K
CPU - Intel dual core e2140
Mobo - Intel 945G
GPU - Nvidia 8800gt
RAM - Transcend 2X1GB
Monitor - Dell 24’’ Wide Screen
SMPS - Intex 450W
CPU - Intel Core i7 2600k
Motherboard - Gigabyte GA-P55A-UD3R
RAM - GSKILL Ripjaws X Series 8GB (2 x 4GB) 1600
GPU - MSI Radeon HD 6850 1GB
Cabinet - Cooler Master elite 342
SMPS - Cooler Master eXtreme Power Plus 460W
Storage - Seagate Barracuda 1TB
No, will not upgrade within 6 months.
Bangalore
Open to online purchase
Yes
Gaming
Browsing
Desktop Processing
HTPC
Watching HD movies
No such dislikes.
FPS - Crysis 2, Ghost Recon.Future Soldier (when released) etc.
Gaming - 1280x720
Desktop - 1920 X 1080
No
Windows 7 64 bit
50K
Mobo - Intel 945G
GPU - Nvidia 8800gt
SMPS - Intex 450W
Bangalore
Yes
Gaming
Browsing
Desktop Processing
HTPC
Watching HD movies
No such dislikes.
Gaming - 1280x720
No
Windows 7 64 bit
