can anyone tell me on wat surface should i keep the motherboard while installing the cpu+hsf & ram?
how to discharge static electricity?
asingh said:Also this link is good to read about various computer connectors. It explains common mistakes, and what is not what.
P.Ping Tom said:4.My mobo has 6 x SATA 3gb/s connectors (SATAII 0 upto SATAII 5), controlled by ICH9R on the South Bridge, and 2 x GSATA connectors (Gigabyte SATA2 chip) for a total of 8 SATA connectors. What is the difference if any between these two connectors? I'm not planning on setting up my HDD's in RAID, so is there any preference as to which device (HDD, optical drive) goes into which connector, and are they supposed to be in any particular order? Eg. primary/boot drive in SATA 0, secondary/storage drive in SATA 1, optical drive in SATA 2 (or GSATA 0) and so on, or can I connect any SATA device to any SATA connector on my mobo? Also have the eSATA bracket w/ 2 ports and the the eSATA port on my cabby that I need to connect.
intelcore2 said:How did u go about applying the thermal paste ? and u call urself a noob:huh:
Be sure to monitor ur temps ateast for about 3-5mins in the bios to see that there is no heating issues causd by applying the thermal paste improperly
anyways cheers to ur new system :hap2:
P.Ping Tom said:Also - can someone tell me how to post pics within a post (like they do in members market/dealers paradise) instead of being attachments at the end of the post?
http://img3.imageshack.us/img3/6781/heatsinkbeast.jpg
asingh said:^^
Yes, you can connect the 3 pin to the 4 pin fan header on the motherboard. You can partition it during OS installation. The procedure will prompt you, you can enter in the partition size(s).
shravank30 said:Thanks for the clarification on the HDD
But it is still not clear which pin i omit when i install the 3 pin in the 4 pin header or it does not matter & i can ignore any of the last pins ?
Please bear with me as this is my 1st experiment with assembling a PC and I may be repeating my queries due to ignorance.
thetechmind said:
asingh said:shravank30:
1. You can put the HDD cables into any slot you wish to.
2. During BOOT the BIOS will ask you which is primary. Of course the one with OS. Set it that time. Or during first BOOT go into the BIOS and set primary HDD in the Boot sequence.
3. The four small connectors can be fitted in any direction (singularly). But the arrangement on the pin header has to be as per the manual. Read that carefully. Your motherboard does has fan pin headers. The CPU HSF cable should go into the fan pin header closest to your CPU. (Close to the first yellow RAM slot).
4. Be careful when docking the CPU/RAM. It is easy to get the direction incorrect and try to force a fit.
shravank30 said:I will put the 500GB HDD in SATA slot1 (This will have the OS)
the 250GB in SATA slot 2
the DVD writer in SATA slot 3
I hope this correct because you forgot to clarify the DVD writer sata slot.
Moreover please confirm that the Sata data cables are same for DVD writers & HDD's ?
