will i be able to watch HD movies even without a GPU ?
@ALPHA17 thanks again will go ahead with the purchase without the GPU , on HD 2000 can we play games like protype at minimum settings ?
7850 GPU which version will be best MSI , ASUS etc etc ... which is the best one and factory overclocked too ... and can the factory overclocked GPU can be overclocked more ?
@ALPHA17 i am planning to wait till the launch of gforce gtx 660ti and if price around 20k will grab that one only .... I was checking the spec of the 660ti , it's memory bus type is 192 bit only which is lesser than 7850 ... so how well can 660ti perform in comparison to 7850 and what's the effect of low memory bus type
@ALPHA17 what is the cost to performance ratio for both the gfx card 7850 and 660ti ?
ALPHA17 can i use HD7870 with my current rig without any modifications ?
@ALPHA17 would it be better if i go for a 2TB harddrive and what will be the price difference between 1 TB and 2 TB harddrive
ALPHA17 THANKS A LOT FOR ALL THE HELP TILL NOW
BOUGHT THIS RIG :-
Intel I5-2400 - 10600/-
Intel DH67 CL - 5300/-
Corsair 4GB RAM -1200/-
2TB SEGATE BARRACUDA 7200 RPM - 6300/-
LG 24X SATA DVD WRITER - 900/-
COOLER MASTER ELITE 430 -2900/-
ANTEC VP 550P SMPS - 3750/-
DELL ST2220L - 8000/-
LOGITECH MK200 MOUSE AND KEYBOARD COMBO - 675/-
APC 600VA - 2000/-
ATI SAPPHIRE HD 7850 - 15750/-
Thanks a lot for all your good suggestions
