31-40k Need help selecting a CPU, Motherboard, RAM, SSD and PSU.
Not sure if you already chose and ordered the cpu but the ryzen 5 5600 is available on amazon atm for 8.2k after a sbi credit card discount and a 1k coupon discount
Good find!
Too bad for me, as I already picked up the AMD 5500GT @ Rs.9139 from Flipkart.
In fact I just received the WD sn770 1TB drive an hour ago.
I just installed Debian on it, and am writing this message from my new system.
Reactions: ThatsSe7en
That's a very old case if I'm correct. Like 2016 old. Get something new. Check this out. Also check GPU clearances. Comes with 4 fans pre-installed so that's money saved
ye thats pretty good, theres this too if u like fishtank style cases https://mdcomputers.in/antec-cx200m-black altho the 5 included fans are molex so they will run at 100% all the time gpu clearance might be iffy for 2 and 1/2 and more slot cards but theres 2 bottom fans that u can either mount underneath where the drives/powersupply go. im looking at getting this case currently altho i havent pulled the trigger ill wait till all the sales seem to be coming to an end
Reactions: YeAhx
I know. It's ancient, and looks it.
I bought it only because all the new cases have the drives stored all over the case, and my PSU has just 1 wire with 3 SATA power cables placed very close to each other. I know that it'll work with the hard drive caddy on the Corsair, and for the other cases I'll need additional connectors. So, I decided to save myself some trouble.
makes sense
Reactions: ch@ts
That's a sweet looking case for its pricing. For DIY enthusiasts they can just throw those molex fans out and install their preferred ones.
Reactions: ch@ts
Write your reply...
