mav2000
Level G
Hi guys, have run into something really odd here. But first the system specs:
AMD Ryzen 3500x
Gigabyte B550 Auros Pro
Crucial 8x2 GB
MSI gaming X 1070ti
Crucial NVME ssd
CM 1000 wards gold psu
Something odd just happened out of the blue today. I was using the system and put it off. A few hours later I turned it on again and there was no video output. The monitor is just a blue screen with no hdmi input.
I first got a new dvid to hdmi cable, but problem persists. I then qflashed the motherboard bios to the latest version, removed battery, cleared CMOS, but still the same issue.
I moved the gpu to another pcie slot, but that didn't help either. Now I am confused as to whether the motherboard is bad or the gpu has gone bad. My last resort will be to take everything to SP road and get it checked. But if you guys have any suggestions before doing that, I could see if that works. I see multiple similar queries on the net, but am unable to see any resolution of the issue. Since the gpu is out of warranty, I only hope it is the motherboard.
AMD Ryzen 3500x
Crucial 8x2 GB
MSI gaming X 1070ti
Crucial NVME ssd
