Need help: System not outputting video
If I am not wrong, you may have bought the card at a high price since mining was at its peak then (March 2018). You should try for 3060ti/3070 and pay for the difference.
They have offered 2060 gaming X. I tried a lot for the super or 2070, but no go. Well, it's not a bad deal and performance is similar, do went for it. Though I have asked for a 5600xt/5700xt
atleast go for 2060 super , tell them that i require more vram you are offering me 6 gb that is not fine
write them performance should match or exceed and vram should match and exceed not looking for a vram downgrade ,directly ask for a 1080ti if you can :p
if they cant help on this ask for escalation asia head ,asian region head
Went to SP road and had the system checked by the guy I know. The 1070ti is dead and not outputting any signal. I then took a copy of the bill and went to Kaizen as it's just opposite. They flatly refused to take the card for RMA even though I still have more than 2 weeks left of the warranty as I had bought it on march 22nd 2018. Now they say I have to get an email from MSI before they will process. This is really unprofessional. Any help with this will be great guys. The guy at the RMA counter says the card manufacturing date is more than 3 years now, so they cannot process it.
This happened to me as well in Nehru Place, Delhi. Refused to honor 2 months of warranty left on my motherboard. They said the exact same thing to me. This is their tactic to avoid RMAs which you can avoid only if you're persistent enough to get a replacement and deal with Emails back and forth argue and waste time.
