Blade_Runner said:Well certain "long-life" LEDs are known to last over 300,000 hrs of use as well. But like i said voltage fluctuations, humidity and temperatures can decrease the life of a LED. So LEDs crapping out early might be a common phenomenon.
Voltage fluctuations = Have an APC UPS and a digital voltmeter on line placed next to computer. Incoming Voltage reads a steady 230 - 235v. Also have PSU voltage readouts on Desktop via Samurize - the 12v is a steady 11.98v
Humidity = Mumbai has high humidity - I have an accurate hygrometer right next to the computer and the read out now is 40%. But are not the LEDs sealed units ? Can high humidity affect them even if the units are sealed ?
Temperatures = my case temps never go over 34C - and one of the fans (which you see in picture above) is in the front panel and should not get affected by any heat inside the case. Behind this front fan are the HDD which are placed at right angle to this fan. Temps now are CPU=30C CASE=29C HDD=27C and 28C
