Solid_Snake
1. Q: What is your budget?
1. 30K
1. CPU - Intel E7200
2. Motherboard - XFX 650i
3. GPU - Nvidia 9800GT
4. RAM - Corsair XMS2 2GB DDR2
5. Monitor - Benq E2200HD
6. SMPS - Corsair VX450
1. Monitor - E2200HD
2. SMPS - Corsair VX450 (only if its good enough)
3. Keyboard/Mouse
4.HDD - WD 750GB
1. CPU - Intel i5 2400
2. Motherboard - any compatible motherboard
3. GPU - 560Ti
1. Yes, will be upgrading a few years down the line
6. Q: Where will you buy this hardware?
1. Mumbai
2. Open to online purchase (only from mumbai) or Flipkart
1. Gaming
2. Browsing
3. Desktop Processing
4. Watching HD movies
5. General Office work
1. No
1. Everything imaginable
11. Q: What is your preferred monitor resolution for gaming and normal usage
1. Gaming - 1920x1080 or 1280x720
2. Desktop - 1920x1080
1. No
1. Windows 7 64 bit /Windows XP
1. 30K
3. Keyboard/Mouse
4.HDD - WD 750GB
3. GPU - 560Ti
1. Mumbai
1. Gaming
2. Browsing
1. No
1. No
