Hey I am confused by your reply. You said that both the 6 port ones (white and green) are essentially the same and you are suggesting not to buy them ?
But in your earlier post it is mentioned that you are satisfied by MX products. :S
Malique
So can we get the same 2 you listed above at Lamington road ? Someone mentioned Soni (IIRC) shop in Chunam lane at Lamington ?
@raksrules i happened to visit the IICF exhibition at BKC and MX had a stall there, i bought this 4 port spike guard for rs. 700 after negotiating from initial quote of 750(MX Price: 975, website price: 780). The 6 port one was quoted for 900 (can be negotiated i feel)If anyone happens to visit lamington road area, request you to please check if the above mentioned model is available and if yes then how much does it cost. Because there is a chance that the same product might be significantly cheaper at lammy.
Which model ?I never updated this thread. I finally got the MX brand, 5 plug points with individual switches for like 400-450 Rs from Lamington Road.
Which model ?
