Pls Help build new system
Depends on the power at your place and whether you need back up or not.
For UPS consider the
APC 550 VA ~ 1.9k
Numeric 600VA ~ 1.55k
Consider UPS with onsite support and 2yrs warranty. More the warranty, the better. Both UPS should be able to give you 15mins~ backup during normal usage.
According to the suggestions I've finalised this
Components Model Description
CPU Athlon II x4 630
Mobo ASUS M4A785TD-V EVO AM3
RAM 2GB 1333MHz Corsair DDRIII RAM
HDD WD Blue/Black 640/750Gb
Cabinet CM Elite 310
PSU/SMPS Corsair VX 450
Ups APC 550 VA/Numeric 600VA
wat about cooling
should i buy CM Hyper 212 Plus?
& should i get extra fans?
Thanks every one for ur help:)
DarkAngel said:
If you are not going to O.C then the stock cooler will do.
i will O.C it later after 1 yr
do i need other fans
i.e
Coolermaster 90 CFM Blue LED Silent
Coolermaster Blue LED Silent Fan 120 1200rpm
My friend says u can put Amd proccy on an intel Mobo
is it true LoL
Guys still confused about mobos
Msi - 1yr warranty
asus-no bios controlled fan support & read somewhere that after sales services is not good is it true?
Biostar not good reviews & mostly mATX mobos
I want a mobo with ddr3,hdmi crossfire,Igp,ide,good after sales serv
should be compatible with nzxt gamma & crossair 450vx wrt (24pin & cpu power supply pin should be near enuf for the psu wires)nzxt psu mount bottom
