You're joking, right? I've been using AMD's drivers and with multiple cards over the years. My 6970 Crossfired cards run rock stable overclocked well beyond their limits and on water. Both vendors have been on and off with their drivers - and I've been using PCs since 1985, before ATI and nVidia were even born - and some forumites. nVidia is not the holy know-it-all either, I've owned enough of both brands and used their drivers extensively - or had to.
Stop spreading FUD. It is your personal experience and probably some issue with your system or setup if the card was all clear. Everything you experience is not gospel truth. Your RAM issue was obviously what was creating the conflict.
First off, I never prescribed it as the gospel truth. If anything, I said that if one is thinking about this card, I'd not recommend otherwise. These problems don't show up in Linux at all. You don't need to have 30 years of PC experience to deduce this.
Secondly, my RAM is perfectly fine and I can say this after countless hours of memtest on each module. The problem is when the AMD card is put in with the RAM. It doesn't persist with the Nvidia card. What would be your conclusion if you were in my place? Has ATI/ AMD ever documented this that the said RAM can cause crashes? Is it anywhere on their website?
I spent good money on my rig. I didn't cheap out on any component. Why should I tolerate any incompatibilities at all? Why should I buy the uncertainty that ships with that product? I don't think is is unwise to spend that extra 2-3k for your peace of mind. I wanted to like AMD this time. I was happy with the performance I got, for about 2 minutes before my system invariably froze each time.
This isn't an Nvidia vs AMD discussion. I have friends who swear by AMD/ ATI and their rigs are great. I have used ATI when 9700 PRO came out. It was awesome.
If you're saying that I'm spreading FUD here, I request you to find a logical explanation for the problem. My configuration is as follows:
GPU: MSI R7850 Power Edition 2GB GDDR5/ MSI GTX 670 2GB GDDR5
CPU: Intel Core i7 2600
Motherboard: ASUS P8Z68V PRO
RAM: Corsair XMS3 2 x 4GB RAM (1600MHz at 1.65V)
PSU: Corsair 650TX
Cooling: Corsair H80 CPU liquid cooling system
HDD: WD Black 1000GB + Seagate Barracuda 1000GB (not in RAID)
Optical: ASUS DVD+/-RW
(note: The only reason why you see so much of Corsair is that my local dealer only sells Corsair. And the fact that whatever they are selling is, to say the very least, passable.)
OS: Windows 8 Pro x64 on UEFI mode
Off-topic: The GTX 670 heats up a lot! On full load it runs at around 88 degrees Celsius and sometimes even higher. Nothing's perfect.. Sigh..
