Revolution said:
I'm using Smart Reliance SIM and have 99 2G pack activated.
From past 4 days I'm not getting more than 5kBps DL speed in EDGE.
Previously I was getting 20-25kBps.
When today I used MDMA saw speed is capped at 64kbps.
Called Rim CC but still no use.
Anyone facing same problem please share!
Yeah, I'm also facing this issue from 4-5 days. Earlier I was getting consistent 27KB/s.
Had called CC yest, he told me to re-insert SIM, so that the "network is re-caught" :rofl:
But in other areas I find rel CC very supportive.
Revolution said:
I can't cos I'm not rich like u.
Rs.900/- for 10GB 3G Rim may be ?
And I have no BB option here at my home.
When I asked CC about plans of 3G, he told me 1GB @ 650
! But I should inform you about a msg I recieved in mobile a month ago.
108 - 300MB
208 - 750MB (I'm thinking to get this)
408 - 1.5GB
All have validity of 30 days and they're far cheaper than any service provider.
But when I asked CC about this, he told me there's no such plan.
They know nothing and just brag.
BTW I'm using 101 plan of GPRS which AFAIK is the only true "unlimited" 2G plan provided in India.
comp@ddict said:
That's nothing new.
Docomo Recently did it. ANd Airtel was 1st ofcourse. GPRS is supposed to give atleast 8KB/s
This situation keeps getting worse
Hardware limit of GPRS is
max 6KB/s. I'm using GPRS from the days when EDGE was not launched in India. With EDGE you get speeds upto 28KB/s.
