dafreaking
I run virtual shows and conferences and broadcast it over the internet.
Once outdoor events start, I will handle software's such as Dataton Watchout and Resolume Arena which are essentially LED Mapping software's.
Have attached pics as to what i do.
As you can see, there is often very less space to work with, and mostly we do shows back to back often in two different cities.
Have also added a pic of one of the systems on a CM Q300l which is not at all sturdy.
Amazing. I've always had polarizing experiences with people into this. My live switcher operator fights with most of them and then I have to put out fires.
Since you make money with this you should really check out that Mechanic Master C26. It's expensive to get here but it's built pretty well and has a handle if that helps. Do you travel with an AIO water cooled system in your check-in luggage or is it in carry-on? Have heard conflicting reports of AIO's being rejected at security. It's the best way to cool systems in a smallish form factor but regular production use with it sounds risky.
This bloody pandemic has put a spanner in all my upgrades. Oh well :fingers crossed:
