Car & Bike suggest me a good audio system for aveo around 25k
Please make sure you use good quality wiring as this makes a huge difference. Also can look at a cheaper amp if need be, the earlier JBL is not that bad either and should be able to run the sub.
here is the quote from Music Corner camp.
hu pioneer 3090 Rs.6500
front speakers illusion electra 6.1 Rs.5200
sub woofer ground zero gztw 12inch Rs.3900 with enclosure
rear speakers jbl 938 Rs.3900
jbl gto a604 Rs.6500 or soundstream amp 320w rms Rs.7000
monster kit wiring Rs.900
installation Rs.500
Total Rs.27900
with bill and warranty..
i am little afraid that the prices are too good to be true
As Chaos said, dont go for the A604 Amp, stick to GTO 1004 as in bridged mode, it will feed enough power to that sub to atleast make it move.
is it that bad ? I have a kenwood 5203 which gives 150W bridged, never felt it underpowered :ashamed:
( and i'm running my comps off the HU)
Honestly, i have never dealt with him so i can't say much about him but haven't rally heard bad things about him.
The prices quoted by him are very very fishy.I double checked the prices with the Hermit Audio who is dealing in these products and then posted the MRP above.
I have no clue whatsoever why is he quoting so low but if he is ready to sell teh stuff which is box packed, with warranty cards etc. i would think, whats the harm in getting them ?
i havent heard of fake illusions.
fake pio speakers, fake jbl wiring kit , yes, but illusions ? are there any fakes in circulation?
here is the probale setup
f/sp illusion electra el 6.1
r/sp illusion electra el 693
amp jbl 1004e
woofer ground zero gztw mk2 12inch
wiring:ground zero gz pk10
total price:30k without head unit
also suggest good hu around 6K
good . I just hope you dont change your mind and install some other crap because your dealer says it is much better or something :P
