challapradyumna Inactive Discoverer Jan 27, 2012 #921 thegatekeeper said: I think it'll be enough for HD4670,it's 72% efficiency but it'll get the job done but anything above hd4670 would be trouble. Click to expand... The box says 26 A - 12V . Some explanation would be great .( Leaning about PSU )
Jakob Explorer Jan 27, 2012 #922 Can you post your full rig,i'll help to decide the psu. challapradyumna said: The box says 26 A - 12V . Some explanation would be great .( Leaning about PSU ) Click to expand...
challapradyumna Inactive Discoverer Jan 27, 2012 #923 Current Config : E5300 Dual Core , Asrock G31 , Nvidia 8400GS DDR 2 2gb 320Gb 5400rpm WD HDD Upgrading Part By Part to Asus P5KC - Bought from TE HD4670 1GB, - Bought from TE PSU - http://www.techencla...ppauge-pvr-150/ DDR3 4Gb - Will buy After PSU 320Gb 5400rpm WD HDD,....
Jakob Explorer Jan 27, 2012 #924 If you haven't bought the psu i would suggest you to get Fsp sagaii 400w-1.9k but if you've bought it then it'll just work.
