The Power Supply Unit recommendation thread!
How does that Seasonic compare to the Antec Earthwatt EA-650 ATX12v v2.2 and the Antec Earthwatt EA-650 ATX12v v2.3 and the Antec NEO ECO 620C 620W?
edit: I ordered the Antec Neo Eco 620c since I found it at a low price.
Hi, I have
AMD Phenom II X2 555 BE 3.2 GHZ (OC' to X4 3.4 GHZ!)
ATI Radeon HD 5770 1 GB (OC' intermittently..)
2X2GB KINGSTON Hyper-blu DDR3 1600 MHZ
2 TB WD 20EARS HDD
500 GB Seagate 7200 HDD
Please suggest me Good SMPSes or PSUs...Probably 500W+ Price range is upto 5K.
I have Corsair TX550W (Noisy fan??) and OCZ ZT 550 (If available, Pricey??) or Cooler Master GX 550(Bad reviews...)
thegatekeeper said:
Get corsair vx550w-4.5k or corsair tx650v2-5.5k,these are the best within your budget.
Thanks for the reply thegatekeeper!
I would like to know if either of these have noisy fans?? big issue for me..
No they are not noisy..
Better get Seasonic S12II 620(80+ bronze) - 4.5K or corsair tx650v2 - 5.5K
Reactions: 1 person
chiragsthakur said:
If you already have VX450 and you need to add a good GPU, then what Megamind has said is spot on... A 6850 should likely be your choice.
Check this..I have posted same comment in other thread as well
Hey I just saw HIS 6870 ICEQ X Turbo X on Theitwares for 11.2K and went through some of its reviews.. It comes really close to 6950 2gb, also beats it in some games ... Just check its review on GURU3d and Tweaktown
Only thing remains unanswered it the A.S.S from HIS in India... Or else this card is seriously bang for buck
TheITWares - One Stop for all Gizmos!HIS IceQ X H687QN1G2M Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Graphic Card
Thank you! I will check the link later from home as it's blocked in office :(
Please suggest a psu for the below mentioned config :
i5 2400 , Intel Desktop Board DH67BL , GTX 560Ti , 2x4gb ddr3 1600mhz , 1Tb+500gb
Budget : 5k max
(should be available in nehru place, also mention the shop if you know)
Thanks for the help
Seasonic s12ii 620w-4.5k would be the best choice for you within your budget,corsair tx650v2-5.5k is another option but the first suggested psu will suffice.
Budget : 5k max
Thanks for the help
Don't know about nehru palace but you can get it from itwares-http://www.theitwares.com/seasonic-s12ii-bronze-620w-atx12v-v291-plus-bronze-certified-active-power-supply-p-956.html
thegatekeeper said:
Get Seasonic s12ii 620w-4.5k which has better built quality than gs600.
yuvi161292 said:
Is it readily available in nehru place??
No, it isn't. NP has only the likes of Corsair and CoolerMaster with a bunch of cheap brands :P
Get it shipped from theitwares-http://www.theitwares.com/seasonic-s12ii-bronze-620w-atx12v-v291-plus-bronze-certified-active-power-supply-p-956.html
It's worth it.
