Never used it.How is the body groomer attachment that came with this model?
using this as body trimmer and its good does the work . amazonDepends on which scissors, hope you haven't tried the usual kitchen scissors. I tried to use rounded edge grooming scissors, it didn't hurt but couldn't get the job done. Maybe a better and safe body trimmer is good for that purpose. I've been searching for such a thing.
Absolutely. Look at the pic, so many comb attachments for what exactly?
Even the body grooming attachment doesn't look any premium, meanwhile they advertise that their OneBlade trimmer's attachment as safest. They should have given that here instead, maybe??
So can you get replacement blades or do you have to buy a new trimmer every couple of years or so?.I have very sensitive skin and I never do shave. If I go for clean shave, I get nasty rashes. If I use cheap trimmers (barber waala), I get rash. This is why I never go for trim outside and have always been using trimmers that come with good blades. Worst I have owned too is from Philips ( It was bad and died within few months (on/off clicker died), blade was really bad, trimmer used to give little bit of itch after few months. I believe this has to do with longevity of blade.
I have to choose between the same, whether this multi grooming kit or trimmer+body groomer. Anyone tried the latter?Thanks for the correction.
How is the body groomer attachment that came with this model? I'm thinking whether to get some other model plus the philips oneblade trimmer vs this 7715 trimmer.
Can you just trim and not shave with this one? I have too much body hair and a complete shave makes them feel like thorns for the week or two as they grow back. So I prefer to just trim them to 1-2mm length.using this as body trimmer and its good does the work . amazon
Did not change till now. Have to check with their service center. I don’t think blades are available at stores.So can you get replacement blades or do you have to buy a new trimmer every couple of years or so?.
The price difference is the quality of the blades.
Body trimmer extension works as well but you may end up with uneven hair.Can you just trim and not shave with this one? I have too much body hair and a complete shave makes them feel like thorns for the week or two as they grow back. So I prefer to just trim them to 1-2mm length.
I too have that problem, I look like a baby if I shave or trim completely, so I tried different trimmers (not premium ones) to see if I can trim the beard to 2mm or so, but it always ended up uneven or weird. I feel this task is better left to barbers or u need lot of practice to do it yourself, if I'm not wrong.Can you just trim and not shave with this one? I have too much body hair and a complete shave makes them feel like thorns for the week or two as they grow back. So I prefer to just trim them to 1-2mm length.
I can get an even trim with a beard, I use a very cheap (800rs in 2015, still going strong) Braun trimmer and you just have to go over multiple times and quickly to even out the hair. Problem is with body hair since it's too soft and long, it doesn't get into the comb of the attachment, so the only option is to do it without the comb attachment which makes it too short.I too have that problem, I look like a baby if I shave or trim completely, so I tried different trimmers (not premium ones) to see if I can trim the beard to 2mm or so, but it always ended up uneven or weird. I feel this task is better left to barbers or u need lot of practice to do it yourself, if I'm not wrong.
Been using norelco 7000 for the groin area for a while now, zero nicks or cuts sinceI once used scissors for my bollocks. Bad idea![]()
Is warranty valid when importing and buying?.Been using norelco 7000 for the groin area for a while now, zero nicks or cuts since
Look for a deal on ibhejo, even though the site looks janky, you do get an original unused unit
Philips Norelco 3000 selling for 1k, seems to have positive feedback. For 3k on Amazon
Philips Norelco Multigroom All-In-One Series 3000, 13 attachment trimmer, MG3750 online at iBhejo.com
Buy Philips Norelco Multigroom All-In-One Series 3000, 13 attachment trimmer, MG3750 Online from USA/America with free shipping at iBhejo.com.www.ibhejo.com
https://www.ibhejo.com/warranty, they say there is warranty, not sure how easy it is claim warranty from them. I’d assume no warranty.Is warranty valid when importing and buying?.
Also, why that model is 1000 rupees is surprising.
So much science and technology evolved, but still no easy way to remove this hair.What is the most popular non invasive solution for hair removal from between the legs?
Scissors and trimmers are all that I can suggest and think of unless someone prefers a wax there.What is the most popular non invasive solution for hair removal from between the legs?
Might work as well, just ensure to apply some fire-proof coating to the essential hangings before firing..
You should try pulling 'em off using your own hands.So much science and technology evolved, but still no easy way to remove this hair.
That's definitely not an easy way and end result could be terrible. What was your experience doing that?You should try pulling 'em off using your own hands.![]()
I am using this for a year and am very very happy. 10 minute charge is enough for two to three uses
Philips Multi Grooming Kit MG7715/65, 13-in-1
