Veek M
Discoverer
Room is 15'x8' wide. Stuff should be visible very close and 15' away?
Cost and longevity is a factor: need to buy a TV for a small classroom - It must have USB/menu-select. This is the primary means of screening lessons so does anyone have any in-depth understanding of the manufacturing difference between a 7.5k vs 13k TV?
There's MI and RealMe - would switching to 43" make any substantial diff from 32"?
Usually more you pay => better/sometimes by a large margin in terms of quality. I feel the MI's okay? Any technical ideas?
Kodak has me worried - they went under in the US so they must be pimping the brand
realme Smart TV - realme (India)
realme Smart TV 2020 in India,is equipped with Bezel-less Ultra Bright LED Display, along with 24W Stereo Speakers with Dolby Audio. Learn more about features and price at realme.com.
www.realme.com
Buy Product Online - Mi India
Xiaomi India official store helps you to discover Mi Mobiles and accessories including ✓Redmi 8A ✓MI A3 ✓Redmi K20 Pro ✓Redmi K20 and ✓Mi Water Purifier ✓Mi Smart Band 4 and many more.
www.mi.com
www.mi.com
