Our fans run 24/7 and the white colour has almost fully gone black!I don't need to use the fan that much which only stirs up the dust everywhere
4.8k
4.8k
You should clean them as it raises the power consumption as they are no longer as aerodynamic as designed. Be regular with cleaning and they will also be quieter.Our fans run 24/7 and the white colour has almost fully gone black!
No, Chennai.You should clean them as it raises the power consumption as they are no longer as aerodynamic as designed. Be regular with cleaning and they will also be quieter.
Aren't you in Delhi btw? yeah different climate there
This is the way I use to check if the floor is cleanThere is still plenty of dust in the air if one switch On a flashlight/torch.
I did consider central AC about a decade ago but the city council decided they would charge more property tax if you had one and that idea was forgotten quickly.The only way to have a clean room is if you have all windows closed, use a duct system which sucks air via a hepa filter and blows them to each room via ducts.
The clean postive air pressure inside the house will prevent dust from getting inside the house.
Not specifically central AC, just a blower for duct with the intake of blower sucking air via hepa filter.This is the way I use to check if the floor is clean
Central ac would take care of the dust. Would keep the temperature comfortable no matter the climate and be more economical than numerous splits.
What to do![]()
What problem is there still ?hahaha...
orthodox brahmin family .. and my mom doesn't allow outsiders inside kitchen .. that would be challenging..
Do you have this setup in your house? It would work better than 6pack's purifier idea.Not specifically central AC, just a blower for duct with the intake of blower sucking air via hepa filter.
The only way to do this in a existing house is if ceiling height is high enough, to hide a duct system with false ceiling.
When I did the calculations the central AC worked out cheaper than individual units in terms of consumption. Upfront would be more.Central AC for home, is going to be a expensive both in terms of initial cost and the maintenance. It may make sense for commerical use but for home use, doesn't make economic sense.
No, this idea came about not due to dust but during the height of covid. I had stopped maid, but one person in the house who didn't WFH got covid with zero symptoms, while it started to spread to others in the house, I was wearing n95 and even 3m P100 full face respirator, while moving around the house but when I was inside my room, I removed the mask or respirator and still got covid during the height of 2nd wave.Do you have this setup in your house? It would work better than 6pack's purifier idea.
This is my advice as an ex-CTO at a startup which specialized in Industrial Cleaning.I live near main road and dust it something i can't avoid as I keep windows and doors always open for ventilation. Please don't suggest AC, prefer natural
Grass broom with long handle for mops.. still takes 45 mins for hall, rooms and kitchen ...
Now I remember. The covid wards the Chinese built in a few days were negative pressure so the pressure in the room has to be lower than outside the room so no germs leave the room of someone infected and spread into the corridors.No, this idea came about not due to dust but during the height of covid. I had stopped maid, but one person in the house who didn't WFH got covid with zero symptoms, while it started to spread to others in the house, I was wearing n95 and even 3m P100 full face respirator, while moving around the house but when I was inside my room, I removed the mask or respirator and still got covid during the height of 2nd wave.
The thing is the moment you open the door all sorts of things from virus to dust get inside. Hell even the key hole is enough. So the solution to this problem was having a room with positive air pressure, this will prevent dust and other air borne particles/viruses out.
This is the thing how to measure when you have more pressure in the room. And the flow rate that will do it. You can then decide on how many fans and size after.The challenges for this was finding a quiet fan, since it will be running 24x7 has to be brushless and have enought air flow to atleast blow the door curtain slightly away from the door, if its able to blow the curtain then that is enough air pressure to prevent dust/ air borne particles to get inside the room.
Agree with your points and that is a good dry mop for cheap. When i was looking over five years ago there wasn't anything like this in the market.This is my advice as an ex-CTO at a startup which specialized in Industrial Cleaning.
A normal floor sweeper broom or that grass broom usually blows 30% dust into the air. That 30% never gets collected in the dust pan at end of your sweeping session. So don't use floor sweeper everyday.
Get something like this >
Something that has sweeper arm longer like 30-40cm.Floor Mop Flat Squeeze Cleaning Supplies 360° Flexible Mop Broom Head Home Floor Cleaner Pro Bucket Mop Broom : Amazon.in: Home Improvement
Floor Mop Flat Squeeze Cleaning Supplies 360° Flexible Mop Broom Head Home Floor Cleaner Pro Bucket Mop Broom : Amazon.in: Home Improvementwww.amazon.in
Learn to sweep your entire house under 2 minutes using this. If it's taking longer than you are doing it wrong. This doesn't blow any dust in the air so this sweeping will keep house rather more cleaned. It's not easy to get corner and tight spaces using such sweeper so you may want to use regular sweeper once in a week.
Don't mop floors everyday unless you have small kids, pets who constantly spew bodily fluids on the floor. Mopping once or twice in a week is okay.
I also like the natural air. I always have my windows open. But then I don't live near the main road and Air Quality Index is green. No pollution.
Thanks for taking time to reply. You're kind sir.I can definitely give try to test dry mop floors instead of broom. Imagine the change in mindset coming from centuries of using grass broom.No, this idea came about not due to dust but during the height of covid. I had stopped maid, but one person in the house who didn't WFH got covid with zero symptoms, while it started to spread to others in the house, I was wearing n95 and even 3m P100 full face respirator, while moving around the house but when I was inside my room, I removed the mask or respirator and still got covid during the height of 2nd wave.
Couple of ideas for making a single room dust and virus proof was to have exhaust fan with in the room, positioned in such a way that it blows air inside rather then sucking air out. Then use a hepa/2.5 filter in front of the exhaust fan suction side.
Also finding a hepa/2.5 filter of the right size or finding one that will be cheap, since it will be used 24x7.
I found atomberg has started to sell bldc exhaust fans, but no idea about the sound.
For the filter I thought I would use the old hepa filter from Mi cut the filter to the desired shame of the fan, use silicone sealant to seal the edges of the cut filter with a 3d printed part which will also act as a adaptor for mounting the filter on the fan.
Biggest job is making a hole in the wall for this, advantage less 3d printed parts.
seal a window with polycarbonate or acrylic sheet, more expensive plus requires several server PC fans with high static pressure, use cheap n95 masks itself as filter. Cons all the fans I bought are not quiet, will also look bad.
Or use exhaust fan but the mount now for the fan as to be an enclosure to accommodate the fan mounted the other way round, cons making it look aesthetically good.
False ceiling and adding ducts is best done in construction stage of a new house.
I will be doing a exhaust fan mounted on the wall method, provided the fan is not loud and has enough air pressure. Only then can I start designing a custom 3d part for that particular fan.
