MS never asked for logging into my MS account as I had already skipped that provision while creating a bootable through Rufus. It asked me to connect to the net to check for updates. No option to skip that part. Anyway to bypass this internet requirement during installation?
Edit- NVM, I found that the command can be used to skip net requirement during setup.
@enthusiast29 @StygianClaw and others..
So I installed W10 on my system last night. Some observations.
1. The battery would charge fast maybe upto 60-70% then it would literally drag to go upto 80 and beyond. It went max upto 87% before sleep.
2. I switched off and put it to charge. It charged to 100%(amber to white light).
3. Then did a usual run on laptop from 6am to 8am by running YT, a movie for 15 mins. The battery drain was acceptable compared to W11 and age of the battery.
4. I did update the drivers from HP(depending on respective company)and for those which were not available, I took from Windows update.
5. I charged my battery yesterday morning upto 80% and in the evening when I powered it on, the battery already fell to 74% despite being switched off. This was on W11. Something's definitely wrong.
I wonder if some sensor is broken or corrupted because both W10,11 are taking a good amount of time to charge beyond 70% when laptop is on. If it's a feature introduced with updates to reduce battery strain, then it's ok. Coz earlier it wouldn't take this much time to charge.
