A adder Innovator Aug 28, 2011 #41 ^thanks for sharing.Its a chimie optronics panel(SMVA) You only notice the difference only if you do a side by side comparison.So just enjoy your tv.
Mohit Forerunner Aug 28, 2011 #42 adder said: ^thanks for sharing.Its a chimie optronics panel(SMVA) You only notice the difference only if you do a side by side comparison.So just enjoy your tv. Click to expand... Just curious. Is this panel the worst of the lot of panels used by Samsung?
F Forerunner Beginner Aug 28, 2011 #43 ^ Yeah. In this order. S = Samsung A = AUO C = CMO Click to expand... S= Super A= Average C= Crap Click to expand... http://www.avsforum.com/avs-vb/showthread.php?t=1178897
A adder Innovator Aug 28, 2011 #44 Mohit said: Just curious. Is this panel the worst of the lot of panels used by Samsung? Click to expand... There is one more panel from chinlin which is also based on SMVA .Which may be the worst.
Mohit Forerunner Aug 29, 2011 #46 think123 said: take extended warranty to protect your lcd and your money Click to expand... Can you give some more details about this?
