Hey everyone,
I have recently relocated to a new apartment complex and my WiFi connectivity has been quite erratic, with frequent dropouts, weak signals in adjacent rooms, and strange ping spikes. Initially, I thought the issue stemmed from my router, but it turned out to be caused by channel congestion. When I scanned with WiFi Analyzer, I discovered more than 20 networks active on the 2.4GHz band.
This is what i did :
Changed my router settings to 5GHz only
Set the channel to 149, which had the least interference based on my scan
Disabled legacy modes (b/g) to streamline operations
Turned off auto channel switching
My teams and Gmeet calls are working fine with this fix. Thought would share, Cheers!
5ghz has more bands/less noise but lower penetration vs 2.4
If you change your router to 5ghz only, devices at some distance from the router will get no connectivity at all .
Instead of disabling 2.4G altogether, try enabling band steering on your AP (if supported)
Else create a separate SSID for 5ghz and use that for specifically for devices that are near to the AP
Thanks for sharing this! I’ve been facing similar issues in my new place too — lots of overlapping networks on 2.4GHz. Unfortunately, my router doesn’t let me manually set the 5GHz channel; it’s always stuck on auto and grayed out in the settings. Super annoying, especially when I know exactly which channel would work best. Any solution?
It’s the default router provided by Airtel — model AOT-4221SR from Sercomm. Seems to be a provider-locked device, so a lot of the advanced settings like manual channel selection on 5GHz are either missing or grayed out. Pretty limited in terms of customization. Any workarounds?
thats an ONT if you are talking about Airtel Fiber, best way to deal with that would be to buy a separate router and disable wifi on the ONT altogether, thats what I have done
Yes, I’m talking about Airtel Fiber so it must be an ONT (I have no idea what that is—will read up on it later). If I buy a new router, what exactly would I need to do to replace this ONT? Since it uses fiber directly, I’m a bit confused. Also, is the WiFi on these custom routers actually better than what the ONT provides?
you just need an ethernet cable from your ONT to your router and thats pretty much it, and yeah ONT wifi range is pretty much shit, I dont use Airtel in my home, but atleast on Jio, My router gives me pretty much 3x the range of the Jio ONT.
EDIT: for more context, this was the router I bought
Just to confirm — so all I need to do is connect an Ethernet cable from the LAN port of my ONT to the WAN port of my new router, and then enable the SSID on the new router, right?
Also, does this kind of setup have any impact on speed or increase packet loss, since it involves passing traffic through another device (the new router) over Ethernet? Just trying to understand if there are any downsides before setting it up.
Thanks!
Yes just connect an lan cable to your wifi router wan port. change your wifi router mode to access point. Or request airtel to enable enable bridge mode for your ont. In your WiFi router use username password provided by airtel to connect to Airtel
Got it, thanks for the clarification! I’ll make sure to use a good quality Ethernet cable. Appreciate the help!
[HR][/HR]
Hey, do you know if Airtel customer care or their engineer easily agrees to set the default ONT (the one they provide) to bridge mode? Or is it a hassle to get them to do it?
On my Airtel ONT, the** **operation mode is set to “Route” and it’s greyed out, so I can’t change it myself.
@@anmolbhard004 is the resident broadband expert but in my limited experience, bridge mode activation is doable with airtel but is a huge pain in the ass, with jio it’s almost impossible unless you get on enterprise plan afaik
just drop a mail to net@airtel.com stating your request and it will be done in 3 days. if its not done in 3 days just drop a complain on cpgrams portal against airtel and it shall be done
their call customer care is pretty much bs now , he can drop a mail to them and it will be done
Ah, that’s good to know. I’ll give the net@airtel.com route a shot then.Thanks for sharing!
Man, I wish I knew this before calling them lol. The operator had no clue what I was even talking about. Definitely just mailing them next time.
Turns out my friend has a JioFiber connection with the Reliance JCOW 411 ONT, and apparently bridge mode can be enabled by the end user on that one. So yeah… just my bad luck I guess
