Lenovo Mini PC Power Consumption
Measuring power consumption of Lenovo Mini PCs was on my bingo card. Finally got the time and motivation, all thanks to “I should probably update to Proxmox 9 atp”.
A bit of context, I run my homelab on a Lenovo M720q with i5-8500T and wanted to install some app, can’t exactly remember what. When I ran the helper script, it failed with an error indicating i have to upgrade to PVE9. So, all this led to me upgrade to PVE9 and measuring the power consumption in the process. Basically, I recorded the power consumption over 5min for each test case (row in the table) and took the average.
Initial Setup:
  • Lenovo M720q Tiny
  • Crucial BX500 500GB SATA SSD
  • 32GB (2x16GB) 3200mhz DDR4 RAM
  • Tp-Link Tapo P110 Smart Plug
  • 1G Uplink Ethernet
  • PVE 9.0.3
For initial testing, I used of combination of default bios settings, tweaked settings, with or without display attached.
BIOS Display Ethernet Idle Power (w) Comments
Stock/Default y n 8w
Stock/Default n y 6w Jumps to 7w constantly
Tweaked y n 8w
Tweaked n y 6w
Note:
  • This is just proxmox, no lxc/apps are installed.
  • Following are the bios settings i used
    Default/Stock
    - OS optimized defaults - y
    - Load default settings - y
    With Tweaks
    - Devices > USB Setup > Rear USB Ports - disabled
    - Devices > Audio Setup > Onboard Audio Controller - disabled
    - Devices > Network Setup > PXE * - disabled
    - Advanced > CPU Setup > Turbo Mode - disabled
    - Power > Enhanced Power Saving Mode - disabled
    - Power > Smart Power On - disabled
    - Security > Require POP on System boot - no
Changing BIOS settings didn’t helped much as you can see, I guess it doesn’t affect that much until unless those features/ports are actively being used.
Now i wanted to test the power consumption with few LXCs/VMs. Unfortunately, i got hit with linux file permission shitshow when i was trying to use PBS to restore my services, long story short, i was able to fix it and restore all my stuff which i thought i lost, but atp the setup was no longer ideal for testing. So, reinstalled PVE which got updated to 9.1.
I then changed couple of things from last time:
  • Crucial BX500 500GB SATA SSD Crucial P3 PCIE3.0 500GB
  • PVE 9.0.3 PVE 9.1
Bonus: I also added i3-8100 (65w) to the mix.
Here are the test results:
Particular i5-8500T (35w) i3-8100 (65w)
Idle (Average) Lowest Peak Idle (Average) Lowest Peak
w/ just display connected 5w 4w 6w 6w 5w 6w
w/o display 4w 4w 6w 5w 4w 7w
w/ ethernet connected (no display) 5w 5w 6w 4w 3w 5w
w/ Powersave CPU Profile 4w 4w 5w 4w 3w 6w
Services + Windows Video Playback 15w 13w 17w 14w 13w 30w
Services (No Video Playback) 8w 7w 10w 8w 7w 11w
Services (Except Windows) 5w 5w 8w 5w 5w 8w
Notes:
  • Every test case inherits the previous test case setup.
  • Services i installed are caddy, adguard, vaultwarden, cloudflared, homeassistant, Windows 11 VM (debloated)
  • I re-installed Proxmox and all the services (from backup) when the CPU was changed from i5-8500T to i3-8100
  • Windows is mad unreliable with mad power spikes. Don’t why there were major spikes with i3-8100. Cause of high CPU TDP? Windows updating in background? who knows.
Takeaways:
  • PVE9 is definitely superior in power consumption compared to PVE8, thanks to debian 13. Right now, my fully setup homelab with 1x PVE node and NAS machine (HP SFF with 2x 4TB) taking b/w 35-40w, which was 40-45w with PVE8.
  • NVME is better than SATA SSD.
  • Don’t attach or keep attached any display.
These results are just my personal testing, feel free challenge or share your experience as well.
Cheers.
Woah, that’s a drastic difference for a single node setup.
My clusters are still on PVE7, I’m now curious about what kind of difference it’ll make.
Definitely for the better XD but upgrading your cluster from pve7 to pve9 would be more challenging than upgrading from pve8 to pve9.
“they did the math” type of thread :100: to the effort put in! :+1:
Is this from wall or reported using software?
Tapo P110 is connected to the wall, and for reporting I’m using Tapo app as the plug can’t report consumption directly.
Don’t mean to derail the conversation, but does anyone know if the P110 is about as accurate as Kill-A-Watt?
Ah sorry just saw this thread 2 mins after posting this reply
Since you are looking at power draw at hardware level and have not gone into micro tweaking of LXC services, I suggest you rerun these tests after running AutoASPM and Powertop on the Proxmox host itself . You will definitely find improvement in results.
I did ran AutoASPM in the previous test runs and i believe it didn’t do anything as ASPM was already enabled for all the devices.
As for powertop, I totally forgot about it :person_facepalming:t2:.
