**I bring to you all mouse and keyboard switches replacement service. So if any of your mouse or keyboard needs switch or encoder replacement then i can do it for you for a small charge.
Available Services:**
-Mouse Switches Replacement or Upgrade
-Mouse Scroll Wheel Encoder Replacement or Upgrade
-Keyboard Switches Replacement or Upgrade
-MillMax Sockets Installation in the keyboards (to make convert any mechanical keyboard to a hot-swappable keyboard)
My Experience Level:
I have been doing this and other soldering related work for a long time. Over all these years i have fixed over 100 mice and over 20 keyboards.
Note: For any questions or quarries you can dm me directly. If you want to send your mouse or keyboard for switch replacement then contact me via dm and i will let you know how much it will exactly cost you.
I am not sure whether I can change a mouse sensor or not but surely I can replace all keyboard switches, even the switches with LEDs can also be replaced.
i dont have mouse feets nor do i sell them, i can apply them if someone wants me to do so. Mouse feet for most mice can be bought online.
The thing I forgot to mention is: for any mouse switches or encoder replacement service i will need to disassemble the entire mouse and in doing so i always heat up the mouse feet well enough so that i dont damage them when they are removed. Basically mouse feet replacement is not necessary because i take care of those feets well enough for reuse.
Thanks. I have a steel series aero mouse with faulty middle click. It’s one of those small microswitches for the middle click. Do you replace those well?
Logitech G Pro X has arrived for switches and scroll wheel replacement. Will be installing Huano Pink Dot Switches in it and Kailh Scroll Encoder in it.
If anyone else is interested in the service then please dm me the details and i will let you know what’s the best possible solution for your mouse or keyboard.
