1 It has a speed controller... you can control the speed thru moboQuad Master said:Noise is a problem then why wud in the first case wud have i got a XP90C.
wudnt i got a ASUS Star Ice cooler better than XP90C cooling is the best and bugging
you with that noise at 60db
Well its seems Panflo and TT Smart LED are the 2 choices now
Does panflow have this
- thermal monitoring diode to adjust speed automatically.
- speed regulator.
2 No. You need to buy a fan controller.
If you need all those, go for thermaltake. I never said its bad
