Checked out some fans for Intake and Exit @ Sidewinder
Also checked Crazy PC , they have high rates as compared to Sidewinder
My eyes liked this
You all might be knowing about it.
Panaflo 120x38mm Ultra High Speed
Specifications: 120x120x38mm,
114.7 CFM @ 2750 RPM, 45.5 dBA, 6.12w, 510 mA, 12v DC, 3 pin Panaflo tail to standard 3-pin connector included.
11.95$
Out of Stock
Logisys 3.5in. Black Digital Thermal Controller
This Logisys Black 3.5†front panel can serve as clock, fan speed controller, CPU/SYS-r/Sys-f temperature and Power/HD status indicators, all right inside an empty floppy bay. The front bezel encompasses a bright blue LED display that relays temperature and fan rpm for each channel, HDD activity, and the current time. A loud alarm warns you of a dangerous temperature presence, or fan failure.
Features
- Monitors CPU, SYS-r, SYS-f temperature
- Monitor the speed and operation of 3 fans
- Alarm for over heat and fan failure
- Compatible for all cases on 3.5" Bay
Cost- 19.95$
At Crazy PC
Panaflo FBA12G12U 120x38mm, 3PIN, 114CFM, 46dBA
Cost - 18.99$
Sunbeam Spiral Liquid CCFL Kit
Description
Light-up the interior of your computer case with this high quality Sunbeam Spiral Liquid Cold Cathode Fluorescent Light Kit. Inside the glass tube an arc of electrical current constantly undulates in a "liquid" like motion. Yes, it induces a hypnotic effect that will entertain you for hours. The Liquid CCFL Kit features everything you need to light your case and installs in just a matter of minutes!
Features
- Includes one Liquid CCFL Light (Length:9 inches of pure light, 13 inches total length)
- Encased in a 100% acrylic shell, enabling 360 degrees of light
- Includes on/off switch
- 4pin power pass-through connector
- Enclosed inverter casing
- Long Lifespan
Cost - 14.99$
Added Later
Thinking of getting the above mentioned Panflo 120mm and will
use it as rear exit and stock antec 120mm provided with 3700BQE
at intake , how is this idea good or worthless
Also forgot to ask , Where can i get Blue Specially , Red , Green LED's in Mumbai.
and each for how much
