DIY Acrylic Case
@iGo
Yes it is difficult to sleep at nite. Realised that yesterday :(
Umm..i wanted the clear one itself
@Sudarshan
Thanks man,
Ill try a make a guide to building that. :)
@SunnyBoi
6mm is too thick man..
I have used 4mm clear acrylic and L shaped aluminium rods.
The structure seems rigid enough.
nice pics there dude..
where are u from?
I have lotsa updates on that case since i made this thread.
Think i should update the pics
Wet cutting and Wet sanding result in smooth edges.
You can easily get Acrilic Sheet from local hardware shop.
Size and thickness according to your design.
I think it was 700 bucks for a 6x4 feet sheet..locally availabe
for cutting u get this special acrylic cutter (60bucks)
u have to peel out layers on the sheet (lot of hard work)
