I have heard front loading washing machines offer superior cleaning. For those of you with experience with both, is this true.
If clothes are dirty yes. If they are moderately soiled the difference won't be as apparent.
Also, heater + drier also required.
What does drier mean ? there is a spin drier but that does not make the clothes completely dry. You still have to hang them out.
Heating is where a front loader wins out because it washes with less water and power consumption goes up to heat water.
You get better cleaning at 60 degrees than 40. If your clothes can take 60. Some cannot. And heating to 40 degrees is a minimum to get the detergents to activate. Think about colder weather where the water in the tank is colder than would be on a hot day where no heating to 40 is needed.
I've done power consumption measurements with a front loader. But not with a top loader as I don't have one.
If the top loader can wash in as little water as the front loader then the difference will be moot. But this point needs to be clarified by some one with a top loader.
Specifically measure how many litres of water used to wash the clothes. Let it drain into a bucket after wash cycle completes and you will be able to tell.
Front loaders wash with 5 litres and rinse with 15 litres. Around there for one with a drum of 50 litres.
How many litres do front loaders use to wash ?
Brand preferences: none. ( though those with good service are preferred).
I have read some bad reviews about ifb after warranty expiration. So...well I'm a bit averse towards IFB.
Service availability helps in case of issues.
The only point to keep in mind here is get a machine that has a drum capacity of 50 litres and not less.
The LG & Samsungs front loaders have models with smaller drums of 36 litres and you want to stay away from them even if they cost 10k less than the next model up.
These ones are always recommended by sellers because its an easy sale.
