nRiTeCh
Level N
T70SJSF2ZA! Got delivered, demoed and ready to use!Which LG did you get and when is it arriving ?
I got this. Did not have 10k more for the front load and my old machine made grinding noise when spinning.T70SJSF2ZA! Got delivered, demoed and ready to use!
Didn't get you. Can you elaborate what you want to convey..I got this. Did not have 10k more for the front load and my old machine made grinding noise when spinning.
Meant to reply to the thread as I was also following it before I bought a new machine.Didn't get you. Can you elaborate what you want to convey..
I didnt went for front load due to space issues at home. And did some research before going for this model else other suggestive models weren't available on amazon/flipkart or even croma/vsps etc.Meant to reply to the thread as I was also following it before I bought a new machine.
Can you measure the drum? Post the diameter and height of the steel part, in cmT70SJSF2ZA! Got delivered, demoed and ready to use!
here is a good demonstration of which detergents to avoid. A bit difficult to distinguish the colours in the video, she should have used a digital pH meter instead.About bad spiders, I'm developing a theory, here me out. I think the biggest reason the spider's rusting is the usage of normal detergent. I don't think many people know there exist specialized detergents for front load washing machine. People must be using regular hand-wash detergent in front loaders. Hell, we used TL for a decede and we never knew specialized washing machine detergents exist. Most general stores don't keep front loader detergent. They even force customers to buy TL detergent for FL.
46 is drum height and 36 is the diameter.Can you measure the drum? Post the diameter and height of the steel part, in cm
I measured it exact vertically for the height without measuring from the center which otherwise might make it 55cms.
Looking at that picture one would expect the height to be more than the diameter as you posted.I measured it exact vertically for the height without measuring from the center which otherwise might make it 55cms.
For diameter, again I measured it straight horizontal from the opening & not base.
Here's how..along the green line!
They are good as no manual hassles like semi-auto thing.Looking at that picture one would expect the height to be more than the diameter as you posted.
This means your drum volume is 47L max for water at the level 10 mark.
If we add the plastic on top which is unused space then the volume goes up to 55L
47L is small, i thought it would be bigger. How has your family reacted to this? I think the semi-automatic they had earlier would be bigger
That means your max load for this is half the drum.
Can you tell me what number water level is halfway?
Your diameter is larger than the depth?Diameter is about 44cm and depth is around 36cm (only counting the actual steel tub height).
Also, it is exactly the same as my old 7kg LG top load.
I'm not happy with this at all. It means recommend only 9kg or more LG top loaders in the futureYes have to compromise on the drum size but thats fine as anyways I was gonna pay 20k for 6.5k and got 7kg for 17.5kg so its only a win win thing for me.
Our country needs more such open testing. However tests could be more scientific. Eyeballing everything isn't a way to go.here is a good demonstration of which detergents to avoid. A bit difficult to distinguish the colours in the video, she should have used a digital pH meter instead.
True. It's a factor I personally never considered before. All of my clothes last a very long time. I make sure to never wring them or put them out in sunlight. pH is one such factor for longevity.pH 12 is too damn high to be washing thinner clothes in. Yeah, it will clean great if all you wash is jeans-like fabric but it will also damage the clothes over time.
Now if @gopal_agrawal can give us some Samsung figures we will see how that one stacks up
Already answered above. Post 373The dimensions are as below
35cm*40cm (l*b) and the height of plastic body above the drum is 8cm
Can you clarify which of the two is the diameter?Already answered above. Post 373
How hard is your water? you need a kit to measure. TDS is not a measure of hardness. You could have dissolved salts giving a high TDS but the hardness could still be low and the wash will be fine. Sometimes there is a correlation between the two but it's not to be relied on. Most people I find are just using TD meters and calling that number hardness. Sexier to have a digital gadget than a chemistry set?Any good cheaper alternative brand for drum cleansing powder?
I thought it was a commendable effort with low-cost tools. She got the point across without burning anyone.Our country needs more such open testing. However tests could be more scientific. Eyeballing everything isn't a way to go.
Been meaning to get a pH meter for a while now. What puts me off is the maintenance. The pH meter has a probe that needs to be kept moist with some buffer solution. Typically there is a sponge in the cap that contacts the probe that needs to be kept wet. If it dries up the probe dies. Use it often all good. Use it a few times and forget about it then it's doneTrue. It's a factor I personally never considered before. All of my clothes last a very long time. I make sure to never wring them or put them out in sunlight. pH is one such factor for longevity.
Not hard at all. Fully soft. Yet no harm doing the cleansing once in 6 months or so.How hard is your water?
