Now there is a different problem. Display is fine, I can select the wash program, set temp, speed etc.
But when I press start, I usually get the red "child lock" symbol and machine starts running. But
now that symbol does not come and the machine just sits idle.
Do you have a blower or hair dryer something? Blow some air through underneath the machine (you may need to remove rat guard sheet if you have one). Blow it for some 15-30 minutes. Make the whole machine a bit warm. I think it may fix your issue. Or keep your machine in good sunlight for a whole day.
Generally which models are good in the front loading space? People are recommending me to go with Bosch, IFB or Siemens.
All of those brands come with sealed tubs. This means changing bearings in the future requires the entire drum assembly to be changed instead of just the bearings as is the case with brands that do not use sealed tubs like Samsung or LG.
Samsung seems expensive than IFB or Bosch. LG direct drive is similar priced. But we have had bad experience with LG in the past with top loading. Didn't last long.
The depth of 9kg machines is the same as 8kg so the drum capacity is the same. I see no advantage in going with 9kg unless you need the features.
Spin speed makes a difference though. A 1,400rpm model typically has a stronger gauge steel than a 1,000 rpm max model. I'd not use the high speeds though to keep wear and tear on the bearings to a minimum
What was the problem then?
Display was not complete, when we select a program the total time was being
displayed as "--".
The only red symbol on my LG is that the door is locked. Any way to reset the machine? might clear up some of these hiccups.
For 2k it's worth a shot.
It's interesting that your problems mostly have to do with electronics. No mechanical problems whatsoever.
Tell us how you used the machine. What temperature washes do you do most often? What kind of detergent? How you maintained the machine etc.
You are right, no mechanical issues. Only this year we noticed that
the noise was much higher.
Nothing special about how we used the machine. Most of the times we
used default settings, so temperature was 40. Detergent surf excel for front loader.
Descaler bought on amazon, we did not follow a regular schedule for descaling.
Always used borewell water.
You want a machine with a clear untinted door. I see a few models with dark tinted doors and that is just not good
They are all touch screens these days and that means contact issues down the road if you see earlier posts in the thread.
Reactions: Kaleen Bhaiya
That could be due to shocks needing replacement or a bearings change.
Very interesting. I suspect your borewell water isn't very hard. My guess is somewhere between 200-300ppm which technically qualifies as hard water but it isn't super hard as in double that as is found elsewhere.
Any idea how deep the water table is in your area? a deep water table means the water is harder and vice versa.
The default for cotton on my machine is 60 degrees but I tend to use 40 for most things and 60 on occasion. Though I've discovered that 60 on my machine is a little over 50 and make it a point to do a 60 wash every four washes.
Please suggest a fully automatic washing machine. Budget 18k, can be stretched if it is worth it.
Tia.
The problem is the budget. For so little all you get is an automated semi-automatic with mediocre wash action. Also, it will be a small tub with an internal volume of 45 litres which is too small. One option here is the Panasonic otherwise you said your mother's machine does not clean well and she uses your machine.
You will get a machine like that for this budget :bored:
Either up the budget or save your money.
Even those brands have sealed tubs now right? My budget is around 35k. Could you suggest some models then. Looking at around 7kg capacity.
@blr_p I went through this entire thread and have come to understand that maybe LG is the best bet. While we have historically used Samsung and never had issues, the LG TL ran into issues in 4-5 years itself and we had to replace it.
Now moving on to getting a new FL, I had initially shortlisted:
1. https://www.bosch-home.in/productli...ogglebox=manuals/Togglebox=accessoriesOthers/
2. https://www.ifbappliances.com/serena-wxs-7-kg-1200-rpm
But after reading the thread I figured I better drop these 2 and look for something in LG.
Some quick inputs that I need factoring the below:
1. Currently we are only 2 and moving into a house in the ground floor. The water tank would probably be in the second floor. So its either 2 or 3 stories above. The issue in this house is I have to do a fix like this attached picture for water inlet (saw this idea in another house). Will this work out for FL?
2. I will eventually move out to my own apartment in maybe 6-8 months (builder delaying) which will be on the third floor and the tank is placed on the 4th floor (terrace) head room. Is this sufficient pressure for a FL. The utility is like a balcony so the machine will be exposed (am based out of Chennai).
3. Parents will move in over time. Can be after 1 or 2 years or more depending on their wishes. So the machine needs to factor this as well.
4. Looks like I am better off buying a machine with 55cm depth and probably 8kg over 7kg. Also maybe with all this touch panel issues wifi option could be an added feature.
5. Is the dimensions of 7kg and 8kg pretty much same as I need to check for space availability.
One of my quotes from Fomra for 7kg LG FHV1207Z4M was 35,500 with CC discount of 2485. So effective price is 33k. But seems like this is 45cm only.
Considering the above could you tell me options within 35k budget please. Would appreciate any quick inputs as I need to fix something in 1-2 days.
hehe, ok then please suggest something good, bare minimum good.
The problem is the tap water temperature. You live in Delhi. What is the tap temperature of water in the winter from Nov to Feb?
Also mention the model number and make of your mothers' top loader. Let's use that as a reference. Got a link?
Reactions: Rockfella
It is for a friend who lives in Punjab. Nov to feb temps are cold, can go in single digits.
Exactly and you too have the same issue. How do you do laundry during those months then?
Pour many buckets of hot water into the machine. It's only needed for the wash cycle.
AFAIK LG & Samsung come with unsealed tubs even today. And you want 8kg, not 7kg. Depth must be 55cm and no less.
Forget the Bosch, the Serena WX if you can find it is a good option that is old school without a touch panel or steam. Note the lack of an S at the end. See this post
Avoid the Serena ZSS at all costs. Irritating thing with IFB is while they may use the model name those letters at the end mean either features added or removed and the ZSS has had some removed that I consider important just to shave off like 3-4k. That is no savings. If you are willing to spend 35k then going up another 5k isn't a big deal.
Why don't you check if FK will deliver to your postcode? From what I can tell it has a low water pressure requirement too so the tank just above should be fine. TN is IFB country so service should not be an issue.
One thing to keep in mind with IFB machines is they don't do load sensing. So for lighter loads, you have to select the modifier to shorten the time. Guess what the ZSS does not have that feature so its cottons washes regardless of load will always take 2h30m+ :bored:
It's unclear whether this IFB has a sealed tub or not. The one person that bought IFB is unwilling to show a picture underneath. Odds are it is a sealed tub.
The advantage of LG is it uses Direct drive. While DD is quieter the more important advantage is the stronger torque and finer control in comparison to belt-driven machines which everybody else uses. This means better wash action and an extra three motions. As a result of the stronger torque, the drum spider tends to be stronger. This does not mean the drum spiders of other brands are weak. It just means the LG is relatively stronger compared to them.
1. Yes. My setup is similar but i don't have the pipe on the ground extended as long.
2. It will be for the Serena I recommended above. @adder mentioned he was not facing any water pressure issues with his new LG even though his tank was just above and his machine's manual states a minimum water pressure requirement that would suggest a tank be at least a storey higher.
3. Hence look at an 8kg machine which gives you a 55-litre drum
4. Yes
5. With LG no they are not. a 7kg is 45 cm in depth and the 8kg and larger models are 55 cm in depth. Due to DD which is mounted behind the drum instead of below like with belt-driven machines which tend to have larger drums as a result for the same weight rating.
Forget any 7kg LG which has a depth of 45cm. It's too small. Even for one person. Consider 8kg and look for models that do not have a tinted front glass if possible.
A couple of things that bug me with the new LGs are they have removed the Rinse hold feature and it's no longer possible to get a warm last rinse. They all have steam now whose purpose I cannot figure out other than its a something extra on their features list.
Head off to a store and try to check the machines you intend to get instead of just relying on online pictures.
Why do you rush into something you know little about? take your time. This is a 10+ year investment. I'd want to avoid buyer's remorse at all costs.
Thanks for the inputs. Could you suggest some models in LG?
I looked at the LG website and shortlisted these to be in 55cm config. But looks like 1400rpm is not there in the 7kg variant
I have to check the pricing to see which ones fit my budget.
But any insights around these models or any other model that is not listed here would be helpful to decide.
8kg variant:
1. FHM1408BDM
2. FHT1408Z2M
3. FHV1408ZWS
7kg variant:
1. FHM1207BDL
2. FHV1207BWW
3. FHV1207BWP
@blr_p The rush is because we are moving in to the new place this weekend and need it by then. Will try and visit some store in the next 2 days.
8kg variant:
1. FHM1408BDM
White variants if you can find them are cheaper than other colours and offer the same features.
This is the plain jane model. Absolute bare minimum as far as LG goes in 55cm depth.
No steam. It comes with a touch panel as is the fashion these days. No rinse hold, no warm rinse. It has no sprays so water pressure won't be an issue. I'm familiar with this kind of model because barring those two features it lacks it's just like mine.
It also does not have Add item. This tells me it will have a higher water level than machines with such a feature.
Is this your first front loader? you seem to have had top loaders before. it will be a surprise to see clothes washed in such little water.
2. FHT1408Z2M
3. FHV1408ZWS
These two will take some time to look into and find proper user reviews instead of useless demo videos that everyone posts. No white variants are available for these that I can find.
I saw an 8kg model with 45cm depth so the kg rating alone isn't always a guarantee of the drum size.
^Avoid that machine at all costs :wtf:
WxDxH
FHV1408Z2M 8 60x56x85 AIDD steam 42k
FHM1408BDL 8 60x56x85 steam 52K
FHM1408BDM 8 60x56x85 steam no-AIDD no-THINQ no-wifi 48K
FHP1208Z9B 8 60x47x85 AIDD steam thinq 55K
FHP1208Z5M 8 60x46x85 AIDD steam thinq 52K
FHP1208Z3W 8 60x45x85 AIDD steam 49K
One thing that caught my attention is the present 7kg ones all have 45cm depth, where as my present one has a depth of 56cm.
What catches my eye is now there are 8kg models with 45cm depth out there :banghead:
Yes it will be my first FL. Wife has used it before at her place. All the ones i listed are 55cm ones since i went into each product page and checked them out myself before listing them here.
Does it make a difference to choose 1200rpm over 1400rpm since you mentioned not to go over 800. I am guessing it's only going to be the longevity of the parts.
The first plain jane one seems to have lesser programs just about 10. It does not have tub clean also.
1,200 rpm machines will be cheaper for the same features. The faster speeds are for those using dryers. If you line dry 800 rpm is good enough
It does have tub clean if you check the specs
The way to activate it is to press that time delay and pre-wash button at the same time. Even says so if you see the text above the display
As for programs what do you need?
Cottons is the default that takes the rated load. This will be your default cycle.
Mix is for cotton mixes. Gentler cycle
Delicates as the name suggests. You could just put delicates in a delicates bag and throw it in the cottons cycle.
Quick 30 for washing new clothes or doing small batches
What I miss is Rinse hold, which is a setting in between no spin and slowest spin speed and warm rinse aka medic rinse on my machine which helps to dry clothes faster in high humidity by doing a last warm water rinse. Cotton extracts the most water when spun if the water it is soaked in is warm as the fibres are more open than if the water is colder. Maybe not an issue for you in Chennai.
It does not have the rinse+ feature to add more rinses so it will have just the default two rinses and if you need more then you will have to run an extra Rinse+Spin program
Something I've noticed with my machine is if the load is closer to a full load (meaning the weight of the dry clothes is 2.5kg+ as weighed by luggage weighing scale) it does three rinses otherwise two. It's possible this is the default behaviour with this model too.
Spirit Level
Get a two foot long spirit level. Two foot will be more precise than one foot.
You will need to go to a hardware store for this. Do not buy them online. No installation guy I've seen in this country has one. So you need to have one to level the machine.
They do it by feel which isn't the proper way. I don't care if they guy has installed a hundred machines that way. Get a damn level.
When you go to the store ask for five. Then find a table and test each one
L----------------------R this is the spirit level laid down on the table, Note where the bubble in the centre of the level is. It will be bounded by two black lines and the bigger the bubble the easier it is to spot when the levelling is off. Typically expensive levels have bigger bubbles than cheaper ones.
R----------------------L Turn it round. Note where the bubble is. If it is not in the EXACT same location as the previous one. Reject. Try the next and so on.
When I got my spirit level, three failed this basic test and I picked the one that was the closest of two. The show owner said I didn't have to test them. I retorted whether he checked them already. When he did not answer I got to work.
A properly levelled machine will make less noise and put less stress on the shocks over time.
No floor, especially tiled will be perfectly level. So you need a level to get the machine levelling bang on. The floor might have a slope which only a spirit level will tell you.
Brand is not so important as you won't find any decent brands around the rs.1k mark which is what I paid for mine.
I wanted to get one by Stanley but since the shop owner decided to cheap out I ended up with one by a brand called Draper. And this was after his store got listed as a Stanley dealer. It's worked fine. My machine has not moved in seven years.
Sorry to barge in but what exactly do washing machines clean? Been using them for over two decades, never understood. Is spinning clothes clockwise and vice versa eventually needing them to be cleaned by hand termed as washing? Are the new machines vastly different from those which came like 10-15 years ago?
3. FHV1408ZWS
Got a link for this ?
See the end of this post for a possible answer and watch the linked video
Whilst carrying out research, the Dyson r&d team discovered an astonishing fact--hand washing clothes for 15 minutes removed more dirt than a 67 minute cycle in the best washing machines currently available. Although washing machines have removed the drudgery of washing clothes they have vastly poorer performance than someone 300 years ago sat next to a river.
Dyson tried to answer that question twenty years ago and failed to improve on hand washing.
Nobody mentions this. Everybody believes these machines are better than hands. Nah. They only save you from using your hands.
They are bigger and have more things to break if you don't stick to simple no frills type machines
what does AI do for you in a washing machine? I can't find anything in that article that makes me go I want this in my next machine.
The new washing machine boasts a suite of features that makes doing the laundry a cinch. Its headliner here is the eponymous AI DD (Artificial Intelligence Direct Drive), which doesn’t just measure a laundry load’s weight, but also the fabrics’ softness. Based on LG’s accumulated data, the wash cycle is then adjusted for each load to better protect its fabrics and extend their longevity.
Huh? what. How on earth does it do that :oops:
The result is 15% less fibre damage. Whatever.....
In other words, gone are the days of having to select "cold" or "hot" depending on whether you're cleaning your white sheets or blue jeans. No longer, my friends. That tedious and remedial task was for the pre-AI days. Instead, let the machine do it for you!
How hard is it to figure this out? Don't use cold. Stick to warm for everything. Or hot when doing towels and bedsheets.
Reactions: sauravghosh
@blr_p thanks for the link and video. Good content. Also, I don't think anyone with a half a brain actually thinks WM wash better than hands do. I mean I cannot speak for ultra bright gen alpha though. For normal folks like us, that bloody thing is used only for heavy clothings, bedsheet and all, where if spots are missed nobody gives a f about.
Have some IFB elite or whatever, it's 5 kg only and while cleaning the machine sometimes shakes so hard it actually moves an inch or two. Wish it had better built. That's why was looking for an upgrade from that 2007 bought machine. But never mind, too much they ask for these good for almost nothing stuffs nowadays.
ok, so that is better than neither having used an FL. Still, there is a mindset that needs to be addressed when moving from top load to front load. The video below demonstrates the pitfalls of not doing so well I think.
This a decent review of an AI DD LG from Malaysia but there are a number of issues with this video.
1) First, this guy is using some no-name dinky one-foot long torpedo level. See above for what spirit level to get.
2) Second, since he is coming from a top loader he expects more water to be in the machine during the wash. He finds wash quality is not so good. He then looks for a hack on the net to increase the default water level and is happy with the result. The downside is his hack will void the warranty. So why did he do this?
Since he is in Malaysia he thinks he can get away with cold washes. He should have stuck to forty-degree washes. That will be more consistent when it is cloudy and the overhead tank does not get as hot during sunny days. In any case, there is no harm in setting it to forty as if the water is hot it will not heat the water up anyway.
The next problem is a bit more tricky. Why is the detergent foaming up leading him to use rinse+ or a third rinse? The reason is the detergent he is using. I notice it had instructions for top loader, front loader and handwash. That right there is a red flag. This most likely is a top loader detergent that is being sold as suitable for front loaders. I already highlighted this issue with P&G India in an earlier post who have since rectified the problem. Not so in Malaysia. When I look at the detergent he is using. It is called Dynamo and the graphics make me think this is the equivalent of Ariel so P&G. A top loader detergent is going to foam more because that is what it is supposed to do. You need some foam to lift dirt & lint in a top loader but you do not want that in a front loader because it cushions the clothes and reduces the wash quality. Right away the formulations are different, they have to be as the mechanics of washing are different.
The fact that he was finding detergent in his clothes in spite of three rinses suggests the water temperature just wasn't high enough. This is why the detergent expected more water to completely dissolve. Since there is no heating in a top loader. Top loader detergents are generally slower to dissolve than front loader detergents. What is interesting to me is this also applies to liquids. This detergent he is using will definitely leave deposits in his drum and cause issues at a later date because it's the wrong bloody detergent. Not his fault. MNCs should not be pulling stunts like this and deserve to be called out when they do. How the hell is any user to know otherwise :mad:
So his problem is using a cold setting instead of warm and compounding that with the wrong detergent. But he finds fault with the machine instead.
The bottle says power gel. Ariel did release a gel about ten years back in Europe. You didn't put it in the drawer but there was a ball that you filled and you put that ball in the drum. The product was a flop and they discontinued it. No ball is offered with his Dynamo gel. Maybe putting it in a small container in the drum would work better. I've had to do this with a detergent I bought recently which is in paste form and it works well that way.
3) As a result of the poor wash quality he questions the utility of low water use in front loaders in the tropics. Simple, it's so it's cheaper to heat up water. Costs more to heat a larger volume of water. Living in a tropical country so don't need to use a heater is bogus thinking I found even with another Indian reviewer who reviewed a Motorola FL. That guy just could not understand why different temperatures are available with a FL. Not there on a TL so why is it needed on an FL. When I asked that Indian reviewer why he did not use powder, he said powder leaves 'deposits'. Well, I never find any 'deposits' in my clothes with the powders I use so could it be the water temperature out the tap at the homes of these two 'tropical' guys just ain't high enough to do the job? :D
4) This video demonstrates well why you do not want tinted glass on the door. It seems like it's another layer of glass on the outer door so there is no hollow like usual in the door. It's hard to see in there even with a torch and no way could I have done the temperature measurements across two panes of glass. This was an aesthetics marketing decision and it overruled the engineers. Poor poor decision. I suppose it's safer when doing boil washes as the second pane will not be so hot to touch. But you should not be touching the pane anyway. And being able to tell how hot the glass gets is a good indicator of whether are things working or not.
Stay away from machines with tinted glass as they are counterproductive. You need to check foam levels from time to time and it's best if that view isn't obscured in any way.
5) The water level during rinse in his machine is an inch higher than mine. He turned that screw to the max water level.
6) Good suggestions at the end about wiping the door, the gasket and leave the drawer open. Though I'd leave it open for several hours not just half an hour.
7) I have never seen that much foam on the drain filter after a wash, he's definitely using the wrong detergent
8) He does admit the front loader cleans much better than his previous top loader where there was hardly any movement in the drum. Poor wash action means poor cleaning.
He did say something interesting. It seems Time delay in these new machines is the equivalent of rinse hold.
Sorry I made a typo. Interchanged the model numbers for 2 and 3.
The correct ones are:
2. FHV1408Z2M - https://www.lg.com/in/washing-machines/lg-fhv1408z2m
That's what Amazon has. Unfortunately, they don't have it in white, only this 'middle black' colour.
3. FHT1408ZWS - https://www.lg.com/in/washing-machines/lg-fht1408zws
But these are 42k and 52k on the website. Not sure which model will come down to 35k.
That model is a little older and has a tinted door which I recommend not get
It adds wifi on top of the one above. And it includes Turbowash. What is Turbowash? check this post.
If you notice yours only says Turbowash. But the better deal is Turbowash 360
And the logo on the machine should indicate 360 after Turbowash.
^This is likely an import. 360 had four jets. Turbowash has only one jet which isn't going to be as effective as four. This machine has a recirculating pump which adds complexity over the plain jane model.
The idea of turbowash is it can shorten wash time cycles by asking the clothes more during the wash cycle.
What I don't like about these models is the tinted glass. If Turbowash 360 was available without tinted glass it would be a good model to look at.
His model does not have a tinted glass. hmm. It is a little noisier with the recirculating pump. Does it really shorten the wash time. There is a caveat
This is the 1 hour wash, which is a downloaded cycle through the app. As with most of the additional cycles in the app, they aren’t actually different cycles but just standard cycles with options preset. In this case, 1 hour wash is Cottons with turbo wash enabled. However if you load anything more than a 1/3 load it will take 3:48 - hardly an hour wash :).
Only if its one third rated load. What does that mean? :bored:
Something else I'm sensing with the reduced water usage of these AI DD models. A full load on my non-AI LG takes 2h30 (in reality closer to 3 hours). Well, these machines with the 'Add item' feature are going to add an hour on top of that. Less water means more time to complete a full load.
40 degrees cottons wash on a full load
In this video the LG is washing a full load on Cottons 40° (the load itself weighed 8.5kg on the bathroom scales). Anything more than roughly 1/3 load on Cottons 40° triggers the long 4 hour cycle. There were some heavily soiled items in here which did come clean, but then I would expect it to after such a long cycle. Unfortunately despite the length of the cycle and the Turbowash jets, the load was not fully saturated at the end leaving some dry patches on garments. A large load such as this would have been very quickly saturated in either the Siemens or the Miele W1. On the long cycle it does do decent length interim spins up to 1400, which it doesn’t do on the shorter cycles times (they only go up to 800rpm on short) and also does 3 rinses rather than 2. Detergent used: Persil Colour liquid and Lenor Spring Awakening softener
How did he manage to get 8.5kg worth of clothes into that machine? Are bathroom scales accurate enough for such a small load?
He really stuffed it full here. This is a 55cm depth machine from the UK.
The absolute MAX of that load is 4-4.5kg and not 8.5kg
So if your full load does not weigh more than 3kg then you're good with turbo wash. My full loads rarely go more than that.
Otherwise it's a 4h wash.
