?dOuBtFiRe?
Herald
This is what we can see that prefilter catches. Pm 2.5 we cant even see easily. So if PM 10 is low and PM2.5 is high then air might look ok but is still bad.View attachment 217089
Air purifier filter in just 15 days.
How much of our lives are we throwing it away by merely breathing in an Indian city?
Pune.@lockhrt999
Which city are you in? What model purifier? In the Living Room or Bedroom?
Very true. There's no visual cue for PM2.5 pollution. It perhaps gives a uniform bluish tint (from the sky) to very distant dark shadows on a nice sunny day.This is what we can see that prefilter catches. Pm 2.5 we cant even see easily. So if PM 10 is low and PM2.5 is high then air might look ok but is still bad.
Yes, in a closed roomDo the air purifiers remove second hand bidi/cigarette smoke? Some downstairs neighbour of mine is a chain smoker and if i keep the windows open, all the second hand smoke comes in my home. I just can't stand the smell and have to close the windows immediately. The smell takes long time to go away. Can these air purifiers help in such case?
I picked up two of these for my and my parents' room. They have done wonders. I wake up with open nostrils, and allergy-related sneezing/coughing has disappeared.Xiaomi 4 lite.
I doubt any Air Purifier works if you keep Windows/Ventilations/Door etc. Open, as they are meant to work in close door environment, check before you buy.Do the air purifiers remove second hand bidi/cigarette smoke? Some downstairs neighbour of mine is a chain smoker and if i keep the windows open, all the second hand smoke comes in my home. I just can't stand the smell and have to close the windows immediately. The smell takes long time to go away. Can these air purifiers help in such case?
The non-lite version comes with a negative ionizer. In theory, it's great to eradicate mold or that stuffy smell you get from mattress and wardrobe clothes. So you may want to put a non-lite version in the bedroom too.I plan to pick up the regular 4 (non-lite) for the living room.
You are right. But I think it's still better to have an air purifier even with the windows open, rather than no purifier at all.I doubt any Air Purifier works if you keep Windows/Ventilations/Door etc. Open, as they are meant to work in close door environment, check before you buy.
My room PM2.5 count goes up quickly when windows are open. Depends on cross ventilation/wind too and how much window is open.The non-lite version comes with a negative ionizer. In theory, it's great to eradicate mold or that stuffy smell you get from mattress and wardrobe clothes. So you may want to put a non-lite version in the bedroom too.
Tulsi plant will be in balcony. What will I do inside the house where there is no sunlight? That guy smokes continuously from 6am till 12am at midnight. I think even plants will die trying to clean the air in my hall. I smell like a smoker even without smoking.
buy pedestal fan, face it toward balcony from where smoke coming in, keep it on and it will partially stop major part of smoke to enter in hall. Out of 4-5 windows panel, just keep open one slide only thus tobacco smoke will not enter in hall from other open slides.Tulsi plant will be in balcony. What will I do inside the house where there is no sunlight? That guy smokes continuously from 6am till 12am at midnight. I think even plants will die trying to clean the air in my hall. I smell like a smoker even without smoking.![]()
How old is your machine? and, did you ask Xiaomi for the filter?Please suggest a filter for Xiaomi Mi Air Purifier 2S.
I need to change it and original is not available.
It was bought in 2018.How old is your machine? and, did you ask Xiaomi for the filter?
