How to clean the inside of a washing machine and keep it that way
Ph test is for testing descaler is it ? It's fine am not gonna use it , since Lizol seems to pull up more dirt than i expected... With descaler i didn't see this at all.
Also particles didn't drain...am running rinse cycle again
pH test is to check if acidic, neutral or alkaline
Good
Right it just dissolves hard water deposits but leaves out the stuff that lizol got out
If you want to DIY a 2 in 1 cleaner. Add a little lizol to a container with little descaler in it.
Check if there is any reaction ie. Bubbles etc or nothing happens?
You're going to have to scoop it out.
Is there any smell in the tub after you finish the second rinse?
Repeat the same procedure tomorrow.
I fished them out , will run rinse cycle now and will repeat entire process tomorrow, thanks
No reaction at all
Reactions: chyawanprash
Presuming your Godrej descaler works. Just add it in with the Lizol whenever you do a tub clean.
Do you live in a hard water area
You see scale around your washbasin and pots?
Yes I do , earlier it was too much, now in my current place feels lesser than earlier , soap froths better here
Any idea why LG don't want us adding citric acid to the plastic drawer?
https://www.lg.com/uk/lg-experience/helpful-hints/how-to-clean-washing-machine/
I've never had any problems. It does not stay in contact with the tray for very long either. Once you add it and turn it on, it gets diluted and washes into the machine.
And there is no need to do the highlighted part. I don't know who came up with this suggestion
Just add citric acid to the drawer and let it wash through as the water fills.
Comparable weight Vitamin C is expensive in India and by the looks of it needs 2x more than citric acid.
Why would you need to combine them when they both do the same job? No doubt it will work but citric acid alone is good enough
Some other points of interest
A self cleaning drain filter? That's a new one :hungry:
Why not mention that citric acid doesn't harm the rubber parts and should ideally be used in place of vinegar?
Epsom salts is Magnesium Sulphate. Price is reasonable for a kilo. But you get the same effect with Lysol or Vanish.
Btw one cup is approx quarter kilo or quarter litre
Note the quantity of vinegar. Around one litre or a full bottle. And quarter kilo of baking soda. Price of baking soda has reduced over the years if you want to use it. But I find it too weak in general.
With my LG front loader I cannot pause the machine for an hour like they said. The machine just empties out after say five minutes for some reason. The only way to get it to soak is by pulling the power for the required period.
@blr_p
I probably left some wet clothes in the machine and now the machine stinks badly , did a tub clean last month only what do you suggest to get rid of the smell ?
Have left the door open of machine from last 1 week but the smell wont die/
What is your update?
hey cleaned it today with lizol and 60% of the smell is gone but some is still there also did a tub clean before running a full cycle with lizol
You understand what's happening here right?
The smell is caused by bacteria & fungi which Lizol kills.
Run another cycle with Lizol and see what it does. You might need more cycles. You must repeat until the smell is completely gone.
That your machine started smelling just because you left the clothes wet in there just once means this problem was already building. And I'm not surprised because you do quick washes. You should do a tub clean monthly to maintain your machine. You can mix your Bosch descaler with Lizol. Once every three months and then the rest of the time just use Lizol.
should the lizol run be at some temp or normal water temp?
40 degrees is good enough. After all Lizol is supposed to sanitise floors with tap temperature water. That is why Lizol is ideal for top loaders. Technically you don't have to heat the water but then you have to let it soak for an hour or two.
You can try with 60 and see if it makes a difference. Higher temperatures speed up reaction and all that. I do everything at 60, laundry included.
Your experience is making me wonder whether it can be used as a quick test to see how dirty the machine really is.
That is, deliberately leave wet clothes in the machine for how many hours was it? Two hours, three hours or more
If the machine smells badly like yours then a proper deep clean is necessary otherwise not.
We can call it -- anmolbhard004's stink test in your honour
If it goes viral you will be world famous :cool:
after running the machine daily alternating vanish and lizol washes for 3 days the smell is fully gone now thanks @blr_p for the help, much appreciated
How old is your machine again?
Samsung suggests do only with water for my front door washing machine ,it heats up water and clean also they say don't use any salts and such
If you use their tub clean program it's a waste of product to add any as the machine drains after five minutes into the cycle so it will be flushed out.
If you do develop a smell problem then you will have to stick to the cottons program and do the longest, hottest wash with it.
I haven't done drum cleaning for an year. Mine is a Samsung top load.
Which powder and what procedure to follow exactly!
For top load, scroll back and do the same as @proletariat
1.5 years
That is quite soon for such a problem to develop and it's down to how you use the machine.
Short cycles, not enough hot cycles.
You have to change your routine.
This is very important because if it happens more in the future then the drum spider of your machine will be at risk. And yours is a sealed tub so this will be a Rs.15k+ fix.
If you continue as is you have around five years before a major fix like that will be needed
Be a shame for that to happen your top end Serie 8 machine
You won't be overdosing as it's automatic dosing in your Bosch I think.
