My car Audio System Config :P
Hes adding up the RMS's of all the speakers :P.
6"x9"s + 6" + 12" Woofer..
Monalac, your Vocals, in the car, will be to low as well.
You should have got 4-Way 6" Speakers for the Front, as well.
It would have a been an Amazing effect then.
^^ You dont talk about Speakers with the Rated Input.
Nominal Input, is how much the Least input is required from the Amp/Deck, to let the speaker run.
The RMS is what you look at usually :).
And below that the speaker would not run? :S
No offense, but the terms are pretty self-explanatory. "Nominal input" or "Rated input" as the word implies is the optimal power at which the speaker presents its best/rated characteristics (in terms of impedance, frequency response, distortion, etc). That does not mean it will not run at power higher than that or lower than that .
