bennysachdev
The twilight cable that you heard my TF10's with is a 50$ cable. I always preferred that cable with my TF10's cuz they are more durable and the sound seems much better(some say its jus psychological but i don't have a 2nd pair to A/B with).BF1983 said:Oh crap, thats bad. I know how you feel when your primary earphone stops working.
Also the TF10s that you heard at Bennys place was with aftermarket cable and a stock TF10 will have a slightly different sound. So you will have to budget in a $75 cable to add to the $250 price of a new TF10.
I would suggest you get a IEM with a replaceable cable as far as possible since the cable is usually the first thing to go and the drivers more often than not outlive the life of the drivers.
Alternatively you can buy a nice amp for your RE0s.
My stock cable broke even after barely using it. The sound comes and goes from one side.
Thats the beauty of the TF10's as compared to other iems. I don't have to throw the IEMs away like with the RE252's, just have to get another cable. And there are a lotta options for UE cables.
Still contemplating ehh???Ritvik said:Probably. Either sell them and get the UM mage or UM TF10 to 6 driver custom. Works out to the same amount if I sell them. Not sure though since its a lot of money.
and yeah, got KMD to help out with the RMA.
Lemme make it easy for you faheem....... when your listening to Strobe - DeadMau5 or Every other way - BT(Armin Mix), what would you prefer, better detailin.............. or more bass quantity and a wider soundstage??FaH33m said:Went through a few threads on RE-0/252/TF10 comparisons and it seems lot of people still consider the detailing of 252 to be better than TF10 .TF10 seems to have more bass quantity and lot better soundstage. In two minds now .. either this TF10 for ~180$ or a new RE-252.
