Why should this happen? Pretty annoying.Maybe it is not able to provide proper current during backup, for lower power readings.
The battery cannot provide the current. Get them checked under load, how many Amperes they are pushing out. The wattage is a factor of load(resistance), potential difference(voltage), and the current required. Your device load of connected articles is fixed, and you measured the batteries some day back for correct voltage. So, I guess, the current draw is not being fulfilled.Why should this happen? Pretty annoying.
Well I got the same Ups from 2009-14 with original 9Ah battery and one fine day it just gave up. During the time it powers up two general desktop (alternatively) and one Mac Mini 2011and Dsl modem and router and it almost on 24x7. But one fine day last year it suddenly stopped. It can't take anything even a phone. Always overload.
Removed battery and checked - Everything is fine (above 12volt). Tried with new 7Ah exide power safe battery and no go. Finally fed up with all UPS shit - this is my 5th Ups from 2002.
Called up local inverter guy - bought 800 va ups+ inverter for 6k as I remember no battery needed as it already there which is 150 Ah Exide Inva Tubular.
Was worried about crossair vx 550 can able to run on the 800 VA or not but it worked like charm. Vx 550 was the reason bought this APC 1500 vs ups.
Finally realized it is not the VA rating that matters, it is battery Ah rating does the job.
One can get a 600VA (invertor come UPS) with 100 AH TUBE battery for almost 10-11k, this will eliminate any need for separate UPS for PC and will give atleast 3-4 hours of backup along with fans/lights etc.. I will never buy a UPS again for my PC. For home uses Invertor(come UPS) is way to go. after 3-4 years just need to replace the battery for almost 6-7k and you are good for another 3-4 years.
I bought a 600 VA APC UPS for 3.2k, it lasted 1.5 years, but once the original battery died, couldn't find the original battery and they were too costly almost 2k online. Exide once didn't last more then 6 months. So got fedup with APC UPS.
Now with 150 AH battery + inverter combo I forget to switch off my PC etc even when power is not there and most of the time I don't even know that if there was a power cut. It can easily last almost 6-7 hours with fans/light etc.
For example below combo can be get in local market for almost 12k. -- with 135AH tube battery. Although I would prefer the Su-Kam Falcon 600 VA + 100AH TUBE battery combo(for low cost purpose).
http://www.batterybhai.com/inverter-batteries-details/Combo-(700-Watt-Square-Wave-UPS- -01-Battery-Model-No.-IL-16000)/248/4/3/135/1
Its calculating power drawn from the battery, and as you know DC needs to be inverted to AC, which has some loss. Its possible that its fairly lossy at low loads.Its just that today I observed, when pc runs on AC current via UPS, wattage shown in Monitoring tool is 137w or so and as soon as the light goes off and pc starts to run on UPS mode, the wattage keeps increasing from default 137w to hooping around 190w. Now why this happens?
The other possibility is since this is primarily a UPS, the power metering part would have been designed with a minimal budget and minimal accuracy.
25k@nRiTeCh
If you do buy a new APC UPS I would highly recommend the SUA-1500i.
Been using it for 8+ years now and only had to change the batteries once (last year). The batteries cost a little over 4k. It gives me around 40 minutes backup for a single PC system. Link in case you're interested -
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=sua1500i
Pretty cool man.
But how much monetary damages on regular electricity bills??
Need some clarification on this.
Its just that today I observed, when pc run************
Desktop was idle at both time when on AC and on UPS mode.
Get a new UPS - preferably a basic one with just an on/off switch and no complicated monitoring software![]()
Yup coz you UPS is attached to the inverter and big external 100ah battery.^^ For me I can't try now,But I'm sure that my wattage didn't use to shoot up when there was power outage. it would remain in the same range as when the main was on.
No that was the case before I got the inverter. Once I got the invertor I have stopped using the APC UPS. There is no need of separate UPS as Inverter(most of the inverter models nowdays) themselves act as UPS. My APC UPS is lying in the box somewhere since last a few months.Yup coz you UPS is attached to the inverter and big external 100ah battery.
