my search for a good air cooled full tower case was going on for a long time,until i found this
i'll be upgrading from my CM690 to this case,but i've decided to make this case one of a kind.
so,here's a list of mods that i've planned to do on this case.
1) Mod the side panel to fit the Lian Li Window.
2) Add support for 2 x 140mm top fans.
3) Add support for 2 x 120mm fans behind HDD Bay.
4) Sleeve every damn Cable.
5) Change all the fans to Xigmatek white LED Fans
6) Tint Side Window.
7) Paint the case from black from inside & white from outside with some designs using other colors.
8) Cut some holes on the motherboard tray for better cable management.
9) Make the motherboard tray removable.
10) Add support for 2x120mm fans on the back side like antec 1200.
11) Mod the front fan support to house 2x120mm Fans.
